Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
how long should V6 brakes last?
I know everyone brakes a little bit differently but in general how many miles should the V6 Stock brakes last? trying to budget for a nicer set up down the road.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
![]() Drives: 2012 2LS Camaro - RIP 10/3/2021 Join Date: Dec 2011
I would guess a long time. I only have two data points for a camaro and a couple other vehicles.
At 5K miles my stock brakes are barely worn, less than 1% Had a student with 20k miles on her car and about 2/3 pad, after 2 hours at CMP (really hard on brakes) she barely had enough pad left to get home (200 miles) Totally different car, about the same weight though - my daughters 2008 Chrysler Sebring Convertible had 80Kmiles on the original pads, just replaced the fronts, rears had a little over 50% And then there is the Tahoe, 50Kmiles and at the last oil change the fronts were at 50% and the rears at 75% Guess would be 60K+ |
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
depends on the driver, but check them at 40,000, most factory brakes will last 60,000
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I have over 41k on my original pads and they are still good.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
I am at 10,400 or so, got a long way to go. will probably replace them long before there worn out at this rate. hopefully in the next two or three years. thinking slotted rotor and ceramic pads but that is a ways off...LOL. thanks for the replys
#6 |
I'm at 19,000 and I just ordered dimpled and slotted rotors from brake performance.com. Only reason I am doing this is because I have a bad pad on my drivers side and it's leaving a grove and squeaks really bad when brakes are cool.
#7 |
I turned over 40k and still good with solid response.
#8 |
![]() Drives: 2LT/RS IBM Sunroof Join Date: Oct 2009
As of today, I'm at 80,300 and still going strong with my 2010 1LT/RS (IMB) with the Midnight Silver 20"s. Only maintenance issue was I wore out my clutch at 65,000 because of how I drive. After paying over a grande out of pocket I take it much easier now on the shifting.
#9 | |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
#10 |
![]() Drives: 2011 ss2 convertible Join Date: Jun 2013
I have a ss2 covertible and have 40,000 miles and their about half gone. They tell me the car is about 4000 lb, so I'm doing pretty good.
#11 |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
I have 61k miles on my 2011 2LT/RS with the original brake pads and I was just about to ask the same question?
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
#12 |
![]() Drives: 2010 Camaro 2lt RS Join Date: Sep 2009
5 years, 70,000 kms, still running the original brakes. I do suspect they will need replacing soon though. probably another year or so.
2010 Camaro 2lt RS, IOM on IOM, M6, eibach springs, eibach sways, ported throttle body, black ice-olator, RX catch can, OBX headers - no cats, Pypes cat back, Vibrant resonators, injen intake, DRL over ride, decepticon fender emblems, transformer sill plates, transformer script on cowl, more to come.
#13 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Not their fault some people ride the clutch. I was actually told there was 0 warranty on the clutch, brakes, & other wearable items before purchasing the car |
