Old 06-05-2012, 12:32 PM   #1
pnoplr1974
Drives: 2011 Chevrolet Camaro 2LT Convertib
Convertible Top Handle Position
Can someone please confirm that after the top handle is turned clockwise to release the top that it should then be returned to the closed position before lowering the top. I just want to make sure that I'm doing this correctly. Thanks!
pnoplr1974 is offline   Reply With Quote
Old 06-05-2012, 12:52 PM   #2
ss409cid
ss409cid's Avatar
Drives: 2011 SS RS Convertible
I always close my handle...
ss409cid is offline   Reply With Quote
Old 06-05-2012, 01:04 PM   #3
pnoplr1974
Awesome! Thanks!
Old 06-05-2012, 01:14 PM   #4
Eli
Eli's Avatar
Drives: 2011 Convertible SS/RS M6
I always close mine and catch it and open it on the way down. Very easy to do
Eli is offline   Reply With Quote
Old 06-05-2012, 01:24 PM   #5
pnoplr1974
That's a great tip! Thanks!
Old 06-05-2012, 01:41 PM   #6
plan-b
No Compromise
plan-b's Avatar
Drives: '04 996 C4S, '11 2SS Convertible
Operate the rocker switch with your left hand. As the top is moving away from you, you can twist it to the closed position. When closing the top, reach up as it's coming toward you then catch & twist before it touches down. Easy, peezy, lemon squeazy.
plan-b is offline   Reply With Quote
Old 06-05-2012, 02:01 PM   #7
HDRDTD
I've never closed mine when I put the top down. 18K miles and all is well.
Old 06-05-2012, 02:07 PM   #8
Justification
Drives: Red 2SS/RS Convertible
I always forget to close the handle too. Haven't noticed any problems
Justification is offline   Reply With Quote
Old 06-05-2012, 02:08 PM   #9
oswego16
2012 2LT Convertible
Drives: 2012 2LT RS Convert Blk/Blk/Inferno
50/50 sometimes i do, sometimes i don't. No problems.
oswego16 is offline   Reply With Quote
Old 06-05-2012, 02:55 PM   #10
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
Owners Manual states to return handle to CLOSED position after unlatching top.
Summit White
Black Leather
3 Pedals
Build Date: 06/27/2011
Purchased: 07/30/2011
Title Received: 08/15/2011
1984 Camaro (3rd Gen.): Traded: 1987
"Meet the new boss. Same as the old boss."
Baba is offline   Reply With Quote
Old 06-05-2012, 03:22 PM   #11
EM9IRE
EM9IRE's Avatar
Drives: 2011 Convertible 2LT/RS
Hope this helps
http://www.camaro5.com/forums/showthread.php?t=149777
EM9IRE is offline   Reply With Quote
Old 06-05-2012, 03:52 PM   #12
saahilrtrivedi
VICTORY 11
Drives: 2011 Black 2LTRS with OrangeStripes
I close the handle. After a while you don't need to stop the top most of the time.
saahilrtrivedi is offline   Reply With Quote
Old 06-05-2012, 07:47 PM   #13
Fnfalguy
Supreme Advisor
Fnfalguy's Avatar
Drives: 2011 Camaro SS Convertible
Same here!
Fnfalguy is offline   Reply With Quote
Old 06-05-2012, 09:11 PM   #14
evlar
evlar's Avatar
Drives: 2011 (L99) 2SS/RS vert
Never close the handle. Pain in the a$$.
evlar is offline   Reply With Quote
