Old 06-06-2012, 11:48 AM   #1
jtzako
Drives: 2010 IBM Camaro SS
Cant get rid of exhaust leak...
I'm putting my stock cats back on after removing the Solo Hi Flow (preparing to sell the car) but it seems the passenger side has a small exhaust leak at the point it connects to the manifold. (I can hear it, and it bubbles a bit with soapy water) It feels properly tightened down but yet its still leaking. Any tips on how to get it to stop leaking?
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 06-06-2012, 12:01 PM   #2
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Did you use new gaskets? Also may try leaving the down stream end loose until the manifold end is tightened.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-06-2012, 12:03 PM   #3
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
+1.
Frid is offline   Reply With Quote
Old 06-06-2012, 01:45 PM   #4
jtzako
I reused the originals since they did not appear worn at all. I guess I can try replacing them. I did have the down stream end loose while I hooked up the manifold end also.
Old 06-06-2012, 02:00 PM   #5
IndeedSS1
IndeedSS1's Avatar
Almost has to be gasket then. Good luck and let us know what you find.
Old 06-24-2012, 09:30 PM   #6
jtzako
OK, I finally got around to working on the car again...
I took the passenger side cat back off since that is where the sound was strongest. I found that the studs that bolt the cats to the manifold where not all the way in. This was making it so that no matter how tight the nut on top got, the thing wasn't sealing.
Once I fixed the studs (7mm socket fits them) and bolted it back up its all nice and quiet again.
Old 06-25-2012, 12:38 AM   #7
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
That's no bueno.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
