![]() Drives: 2010 Camaro 2LT V6 Join Date: Jul 2009
Vmax 1inch IM iceolator and Plenum Iceolater
Has anyone had a chance to put on this combo? The Vmax plenum iceolator measure 10mm as opposed to Mace's 12mm. Would that make a noticible difference?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace SS Brembo Brakes, Racing Brake Stainless Lines |
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
You are not going to have a noticeable difference with 2mm.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
