Old 06-08-2012, 08:02 PM   #1
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
Anyone who Supercharged 1st Headers Later ?
I had a Whipple Supercharge put on my L99 Camaro.
Now I'm thinking I want even more
Anyone done this and think it was a waste of budget that could have been used for gears , suspension or better wheel/tires?
The installer is telling me that headers and intake are a great Bang for the Buck on a stock car,,, but I might be dissapointed adding them now.
Probably only get 30-35 more RWHP .
And to get that 30-35 HP will require a new pulley and a new tune, so basically another $1500+
And the High Flow cats might be a problem now that its supercharged.
Basic discussion was gears would be the next best move.
Indyblue98 is offline   Reply With Quote
Old 06-08-2012, 08:38 PM   #2
Dan2510
Drives: 2012 LS3 2SS/RS IBM
If you go with a 2" header I think you'll get more HP then 30-35. Regardless, yes its a great add to a heads/cam and FI car setup. Plus, there's cheaper options then 1500 bucks you need to shop around.
Dan2510 is offline   Reply With Quote
Old 06-08-2012, 08:43 PM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Smaller pulley almost definitely. But a pulley is only like a hundred dollars.
The headers open up that power number on a stock car.
Letting your system breath better AND smaller pulley could get you way more than that. Especially to pulley down.
Plus it will sound WAY better.
Old 06-08-2012, 08:59 PM   #4
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
I did my supercharger first. After I installed the headers and got a tune I gained 44rwhp/50rwtq
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 06-08-2012, 08:59 PM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Pulley. Or gears. Headers won't make big gains FI. 20-25 whp which is claimed on lngtubes under FI have really not been backed up here on these forums. I posted and dropped the gauntlet for a dyno graph. Never got one. You can make almost the same power with the cats deleted. Now...if your goal is every last inch of hp with all hell thrown to budget, then by all means order some lngtubes. They will make for a more efficient machine and will make a small difference. Is up to u as to what $1000 is worth to u.
-John S.
Old 06-08-2012, 09:00 PM   #6
PQ
Booooosted.
PQ's Avatar
With smaller pulley?
Boost go down?
Old 06-08-2012, 09:01 PM   #7
Chris82xx
Chris82xx's Avatar
Pulley stayed the same. Not sure if anything happened to the boost.
811RWHP/719RWTQ
Old 06-08-2012, 09:23 PM   #8
Chris82xx
Chris82xx's Avatar
The pulley is already the smallest it can go, ECS uses restrictor plates. So, for instance, instead of being unrestricted and having a 4" diameter opening, there's a plate with a 3.5" diameter opening.
811RWHP/719RWTQ
Old 06-08-2012, 09:53 PM   #9
Indyblue98
2012 RS 2ss
Boost go down?
From what a couple Tuners have told me , on a whipple the boost will drop 1 to 1.5 lbs with headers .
So no pulley change will make the engine run more efficent, but maybe only gain 10-15 hp .
Pulley down to get the boost back and get 30 hp.
Oh , i really don't want a loud car either , but most say that header/high flow cats don't make that much more sound with the resonator and mufflers being stock.
Old 06-08-2012, 09:56 PM   #10
PQ
Booooosted.
PQ's Avatar
Ah. Got it.
Hmmmmm............. In that case I might go with gears or a Stall converter.
Old 06-08-2012, 09:57 PM   #11
PQ
Booooosted.
PQ's Avatar
I not lowered yet then I'd do that before anything else.
Old 06-08-2012, 10:41 PM   #12
Indyblue98
2012 RS 2ss
Had the PFadt rear suspension and Diff bushings plus Trailing arms and Toe Rods put on.
Would like to do Coil overs instead of just the lowering springs, but thats a pricey step also.
So many ways to spend more on mods.
Old 06-08-2012, 10:45 PM   #13
PQ
Booooosted.
PQ's Avatar
So torque converter or gears.
Old 06-10-2012, 09:14 PM   #14
Jims73z
Jims73z's Avatar
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6
O
Jims73z is offline   Reply With Quote
