Old 06-11-2012, 11:28 PM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
Rx or IPF supercharger?
can anyone make a case for either one?
Khmero215 is offline   Reply With Quote
Old 06-11-2012, 11:58 PM   #2
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
RX kit has a separate belt to take stress of the already over loaded serpinten belt. And if the sc belt breaks you can still drive the car unlike others that are all run with the same belt. If it broke you are stuck on the side of the road. Tracy also provides top notch customer service and will do anything to help and asks for nothing in return. I personally went with the RX Performance S/C and can't wait till I recieve it and do an at home install!
But that's just my .02
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 06-12-2012, 12:26 AM   #3
Khmero215
Khmero215's Avatar
Are you concerned you might run into issues doing the install yourself instead of sending it there?
Old 06-12-2012, 12:30 AM   #4
V6owner
V6owner's Avatar
Nope Tracy has no problem walking me through something if I get into a pickle
Old 06-12-2012, 12:34 AM   #5
Khmero215
Khmero215's Avatar
Cause I was leaning toward on getting the Rx SC sent here and have a local speed shop install it. But I'm worried if an issue arises they wont address it. They deal with muscle cars all day but not everyday someone is SC'n a v6.
Old 06-12-2012, 03:30 AM   #6
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
I think you will be fine. From what I can tell the IPF set up seems to be a well engineered set up but at the moment is not set up to deal with existing mods you may already have such as LT headers full catback ported IM/TB, insulators but I do believe they are working on solving those issues by coming up with tunes to accommodate additional mods.
RX's system seems to have more options like the Super Chiller, high pressure fuel pump etc and it seems to be more mod friendly at the moment. They both use the same Vortec v3 head unit so similar but with the extra options RX has, I think you'll make more power with the RX system at this time.
They are both good options and it really comes down to what your wants and needs and goals are. One of the things I'm looking for being that my car is in a lot of car shows and on display 6 days a week is a system that says very loudly "I'm SC'd" and RX's system visually has more of a WOW factor. The IPF set up is a very clean almost factory looking install and you really have to know what to look for to know it has a SC under the hood. Great if you're going for the sleeper thing. If you want any chrome or polished bits, they charge extra. Otherwise it's black which is cool too.
Good luck.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 06-12-2012, 04:00 AM   #7
Mach
Mach's Avatar
Drives: White M6 1LT RS
I agree with Six.. The RX kit is great for upgrades.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 06-12-2012, 07:23 AM   #8
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
SixJak broke it down to you in a great way. Both get systems working towards the same goal of giving us V6 owners more options. Like Six said for now RX offers a mod friendly tuning solution. But IPF suppose to be addressing that soon.
Can't_C_Me is offline   Reply With Quote
Old 06-12-2012, 10:31 AM   #9
SC2150
Thanks all. I would add one more point, the RX system has an optional billet overdrive crank pulley so you have the option of more boost, and we have the higher output fuel HPDI fuel pump available. The RX system comes with the RX dual valve oil separating crankcase evac system standard and the guage pod and wide band A/F and boost guage.
Old 06-12-2012, 10:49 AM   #10
V6owner
V6owner's Avatar
I have the Overdrive crank pulley on my kit I ordered!
Old 06-12-2012, 11:36 AM   #11
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
simply put if you are a mod addict go with the rx system they have the options to increase hp/tq above the standard ipf supercharger.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 06-12-2012, 12:12 PM   #12
Make It Rain
Drives: 69 Z28
I went with the IPF because:
1. You can get a warrnty, at a cheap price for peace of mind.
2. I could determine from the IPF kit how much power was actually gained, and I knew it worked.
3. The dedicated belt in my opinion, puts additional strain on the engine's crank.
4. My installer said that the 60 page installation manual was very easy to follow, and the fit was perfect.
5. It does have a crankcase evac sytem.
6. I also wanted a system easy to remove when the car was sold, so that I could resell the kit, plus the car will have a better resale value when it is returned to original.
I am sure the RX system is great, because the one that has it say's he likes it (and I will get bashed for this), but I have not seen one piece of information with actual dyno numbers or 1/4 mile times for the RX system. How does anyone know that it actually puts out more HP than the IPF? Even with all the exra mods.
The IPF system is also much faster to have shipped and installed.
This is my opinion and I am not bashing anyone else's system just trying to explain how I came to my decision.
Make It Rain is offline   Reply With Quote
Old 06-12-2012, 12:17 PM   #13
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
You can get a warranty for the rx system as well.
Old 06-12-2012, 12:41 PM   #14
SIXJAK
SIXJAK's Avatar
Well along those lines of proof, Make It Rain none of us here on this forum have anything but your word that you in fact purchased these two kits. Just sayin. It would be great if you posted up some pics or videos....anything...a write up perhaps of how the vehicles drive....I for one am genuinely interested in seeing the V6 beasts. The more the merrier, we all win.
I know you say you dont know how to post pics or video but trust me if i can do it, a monkey could do it. I'm by no means a tech savvy person. Thank heavens for my iPhone and the Tapatalk app. I can post video to YouTube in a matter of minutes and post a pic on this forum of anything I want. If you have an Android or iPhone and a computer, you can easily do this.
