The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Fuel Mileage Improvement with CAI intake.
I installed my Cold Air Inductions this winter with about 4300 miles on the odometer and the DIC showing fuel mileage of 17.8 mpg. I did not reset the fuel mileage calculator when the CAI was installed. I have driven a little over 600 miles and the DIC is showing 18.4 mpg. that seems like a pretty good improvement considering the previous 4300 miles were rolled into that calculation and since I am enjoying the new sound it's kind of hard to keep my foot out of it.
I guess I will reset my mpg calc in the DIC and see what happens.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Winter gas versus summer
? I've never seen any mpg difference plus or minus, between stock, C.A.I., Halltech, or Vararam. If there was a difference it wasn't enough to make note of. I've averaged 19.x to 20.x mpg combined over the past 37k miles.
She is only memory now. |
#3 | |
The DREAM is free... It's the HUSTLE that is sold seperately
Chillin Like a Villain
Drives: 2013 2SS Blue Ray Metallic Dusk Ed. Join Date: Apr 2011
Drives: 2010 Cyber Grey 2SS Join Date: May 2012
I got a huge bump in MPG after I installed long tube headers, full exhaust, and a CAI and got a custom tune. At 65mph on flat ground, in cruise control, my MPG reading is a steady 28.1. While this may not be completely accurate, it shows an improvement of the same speed on the same road the day before the tune when the car showed 23.9mpg.
Needless to say, my tuner is a guru! |
#6 | |
I don't put winter gas in my car.
#7 |
![]() Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
My biggest gas mileage gains came from driving 65-70 and airing my tires up to 36 psi. I can maintain ~26 that way. Drive 80 and it drops to around 21.
Summit White 6" Lift, 37x13.50R24's |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
My mileage went up about that as long as I drove like I did before the cold air kit......
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#9 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
If your factory tune is on the rich side you should always see a improvement if driven the same. Winter/Summer fuel mix also has a impact.
#10 |
Drives: Florida Speed & Power Join Date: Jan 2011
#11 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
+1, Especially on my truck which gets 12 mpg at best! We hear anywhere from a 1-4 mpg gain, but I would say around 2-2.5 is most common. It mostly comes down to driving habits. Curious to see what the OP gets!
#12 | |
Stay tuned (no pun) I will reset the DIC and see what number it throws after several hundred miles.
#13 |
#14 |
![]() ![]() Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
mine went from 13.5 to 14.5, but that is no highway and not driven daily.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
