Old 06-13-2012, 05:52 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
MAF Cleaner
I have about 40k miles on my camaro and I like to make sure everything is maintained properly. Should I clean the MAF sensor? Is there a scheduled time when I should?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 06-13-2012, 05:57 PM   #2
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
? curious as well
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 06-13-2012, 06:04 PM   #3
JohnZ
JohnZ's Avatar
I know that if its dirty it can lead to reduced power and I don't want to possilbly leave any HP on the table.
Old 06-13-2012, 06:21 PM   #4
Mach
Mach's Avatar
Drives: White M6 1LT RS
CRC makes a Mass Airflow Sensor Cleaner.. you can get this at your local autoparts store.
I cleaned mine.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 06-13-2012, 08:00 PM   #5
JohnZ
JohnZ's Avatar
Thanks Mach. How far away did you hold the can from the MAF? I know it is delicate and i don't want to mess anything up.
Old 06-13-2012, 08:09 PM   #6
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
I spray the hell outta mine every oil change. I use a K&N air filter and the oil from the filter gets the sensor rather gunky looking. It might be a mind thing but everytime I do an oil change and clean the sensor and air filter i feel as if my car has a new personality!
2010_camaro is offline   Reply With Quote
Old 06-13-2012, 08:42 PM   #7
Midlife Crisis
Midlife Crisis's Avatar
Drives: 2LT/RS
I do mine every oil change as well. Can't hurt takes a minute to do.
Injen CAI, JBA Shorty, MRV2, Vmax Throttle Boby,Mace 25MM,Ported Manifold,3.73 Gears,Barton Shifter.
Midlife Crisis is offline   Reply With Quote
Old 06-13-2012, 08:56 PM   #8
RS/4Life
RS/4Life's Avatar
Drives: 2014 2ss/rs
Works for me......
RS/4Life is offline   Reply With Quote
Old 06-13-2012, 08:57 PM   #9
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
I cleaned mine.
+1
I do mine at every oil change as well. I just did it on both my Camaro and my company vehicle 2011 Expedition on Monday. The Expedition had a slight rough idle and after cleaning it the idle smoothed right out. Never hurts to clean them and it only take 5 minutes to do it on all vehicles.
SlowSS is offline   Reply With Quote
Old 06-13-2012, 09:35 PM   #10
Rangore
Rangore's Avatar
Just spray on and leave it on or wipe off?
Sorry...never cleaned the MAD before.
Old 06-13-2012, 09:56 PM   #11
Mach
Mach's Avatar
Just spray the crap out of it.. Then let it dry. It super fast drying. Takes about 15 seconds to dry from being totally wet with cleaner.
Next mod: Done!
Old 06-13-2012, 10:02 PM   #12
JohnZ
JohnZ's Avatar
Cool guys, i am going to buy some right now.
Old 06-13-2012, 10:24 PM   #13
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I clean my MAF sensor frequently, but never use the high velocity red straw. You can damage the sensor with too much direct pressure.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-13-2012, 10:28 PM   #14
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
On today's vehicle the MAF is the main load bearing device. It helps calculate automatic transmission pressures and many other items. Cleaning it every oil change is an excellent idea. Let it cool off for about 10 - 15 minutes, than spray it down good , let it dry and try it out. If yours is easy to remove, it is best to take it out, clean it than put it back in. This way the cleaner and the dirt are not in your intake tube going right into the motor when you start back up. We do a MAF cleaning with every transmission rebuild at my shop. customers think it is all because of the transmission repair that has brought back life into their vehicles. It also protects our work we did by maintaining proper transmission pressures.
etmx183 is offline   Reply With Quote
