Old 06-21-2012, 02:07 PM   #1
tangomike7
Drives: Born Mar09
So how $&%$!* am I? Help, See Pic...
By no means am I a uber gear head. I am however pretty mechanical and do basic maintenance on my vehicles. I have changed the oil in my V6 Lt about ten times and have roughly 30k on it. I was removing the upper oil filter housing and the cast nut broke off. This was not over torqued and I tightened to 20NM on every change. The nut literally broke off in a peculiarly pathetic way. New upper housing ready to pick up from GM parts tonight. I can't find a nice (non AL) stronger aftermarket upper oil filter housing anywhere online. Soooo.....how do I get the old filter cap off without surgery? Award winning photography attached.....
tangomike7 is offline   Reply With Quote
Old 06-21-2012, 02:09 PM   #2
Scrapppy666
Scrapppy666's Avatar
Drives: 2010 2SS/RS M6 Black/Black
Looks like a casting flaw to me
Pittsburgh Automotive Photography
Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake
Scrapppy666 is offline   Reply With Quote
Old 06-21-2012, 02:11 PM   #3
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
um are ya still under warranty? If so wouldn't they come get it and flatbed it to the dealership and fix it under the warranty?
If not I think your title said it all, buddy. Good luck with that!
Tori
Old 06-21-2012, 02:11 PM   #4
jdenotter
jdenotter's Avatar
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes
Yep. Id have it towed to the dealership and make them fix it
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit.
jdenotter is offline   Reply With Quote
Old 06-21-2012, 02:20 PM   #5
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Try using a strap wrench. Like this.
http://www.google.com/products/catal...d=0CK8BEPMCMAQ
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 06-21-2012, 02:48 PM   #6
Rip
Drives: 2011 SS/RS
He can try to get them to fix it, but my guess is they will say he overtightened it and it's his fault.
Rip is offline   Reply With Quote
Old 06-21-2012, 02:50 PM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
This!
FSP tuned: 377/389
Old 06-21-2012, 02:54 PM   #8
Mach
Mach's Avatar
Drives: White M6 1LT RS
That will NOT be covered under warranty. He did it. Now if the dealer was changing the oil and did it then different story.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 06-21-2012, 02:55 PM   #9
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
The strap wrench might work, however there isn't much room in there.....
NOW. since you have the new housing (cap), what you could do, and what I would try, seeing as how the hole is oblong and not round, I wound find something like a combination wrench (the open end) that will fit in the hole, and use another wrench to turn it.
oh and btw Mike..... Welcome to our happy little corner of the net, and to Camaro5. There is a BIG fridge on the back porch with anything you can think of in it...help yourself...of course only take what you can LEGALLY have. Make yourself at home on one of the big fluffy couches, kick your shoes off, put your feet up on one of the tables, yes we are allowed to do that, mom's, wive's, husbands and boyfriends here don't care....and take it easy.
Welcome!!
Old 06-21-2012, 02:56 PM   #10
vafinest25
vafinest25's Avatar
Drives: 2010 2SS/RS "Orange Crush"
Wow!!
" When your ready to quit, your 1/2 way there"
" Drive It Like You Stole It "
[SIGPIC][/SIGPIC
vafinest25 is offline   Reply With Quote
Old 06-21-2012, 02:56 PM   #11
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
I would find something like a combination wrench (the open end) that will fit in the hole, and use another wrench to turn it.
This.
TheHorse13 is offline   Reply With Quote
Old 06-21-2012, 02:56 PM   #12
SB09
SB09's Avatar
Drives: 2012 SS/RS M6 AGM
That's a nice one. Real nice. Good luck getting it fixed up! I still think that, no matter how hard it was torqued, the casing wouldn't just rip apart like that. That was alotta force.
Pin it to WIN it!
SB09 is offline   Reply With Quote
Old 06-21-2012, 02:58 PM   #13
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Agreed definately a casting flaw.
Evil-Bee-NH is offline   Reply With Quote
Old 06-21-2012, 03:00 PM   #14
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
its actually kinda easy i see this alot at my dealer i work at take a hammer and a punch and tap it around the bottom till it moves then just replace with new cap and new cap comes with a oil filter i think its like 22 dollars
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
