06-22-2012, 11:43 PM | #1 |
Drives: 2012 2LTRS, Join Date: Jul 2011
Door projector light and door sills
Really like the look of these LED projector lights mounted in the doors. I also installed LEDs to light up the door sills. Only bad part is, I only get to enjoy them when it is dark out.
06-22-2012, 11:47 PM | #2 |
Account Suspend...Right
Drives: Synergy LS & Vulcan 1600cc Join Date: Apr 2011
looks awesome man
06-23-2012, 12:20 AM | #4 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I have the door lights too, but haven't installed them yet. How did you wire them?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
06-23-2012, 04:56 AM | #5 |
HT5 COTW 9/3/2012
Noiiiiiiice
06-23-2012, 09:26 PM | #6 |
I hooked into the dome sensor wiring coming off of the BCM. Had to run wires into the doors. Used a hole already on the A-piller near the top hinge and drilled a hole in the door near the electrical plug. Used a piece of 1/4 inch hose to protect the wires and give a finished look. I first tried to use wires already in the door to avoid drilling but the timing on the door latch switch that I was trying to use was not working like I wanted it. So I drilled. Looks good and works perfect now.
06-25-2012, 12:10 PM | #7 |
LocoBee in da RGV
Drives: '10 Custom RY 1LT, '14 BlK SS/RS Join Date: Jul 2010
They have the lights on ebay here: http://www.ebay.com/itm/New-Chevy-Cr...item3f169aba17
It is better to deserve honors and not have them than to have them and not deserve them.
2010 Camaro 1Lt Custom 2014 Camaro 2SS/RS Custom |
