Old 06-23-2012, 03:54 AM   #1
CharleyKahleys
CharleyKahleys's Avatar
Drives: 2011 2SS/RS cyber gray/black strip
Whats the best/cheapest way to black out my wheels?
What's the cheapest way to black out my wheels?
some guys want $500i think it worth it but wanna see if I can find it
A little cheaper,
Thanks!
CharleyKahleys is offline   Reply With Quote
Old 06-23-2012, 03:55 AM   #2
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
plasti dip
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 06-23-2012, 04:07 AM   #3
iKeablr
iKeablr's Avatar
Drives: Chevrolet Camaro 2011 RS 1LT
Yup Plasti Dip. It only cost about $6 a can and you would only need about 3 cans for 4 20" rims. That is what I did.
Camaro 2011 VR 1LT RS - Prometheus Prime
|Leather Interior|Leather Door & Dash Trim|12" Subwoofer|Dash ABL|Plasma DRL|
iKeablr is offline   Reply With Quote
Old 06-23-2012, 04:15 AM   #4
Mister-Camaro
Mister-Camaro's Avatar
Drives: 2011 2SS L99
Pretty much this
http://www.amazon.com/Plastic-Dip-In...ack+plasti+dip
Mister-Camaro is offline   Reply With Quote
Old 06-23-2012, 04:23 AM   #5
CharleyKahleys
WOW that is great, does it scratch or peel when washed?
And where can I get that?
Old 06-23-2012, 04:28 AM   #6
iKeablr
iKeablr's Avatar
I go through a machine wash weekly and it hasn't came off since. It can withstand even some powerwashers, not all. I've had it on for a couple of months and had no problems. You can buy this at The Home Depot or Menards. The only two places I have found them at and I looked everywhere that sells spray paint.
Old 06-23-2012, 04:29 AM   #7
HP Turbine
Boosted
HP Turbine's Avatar
I've heard it holds up pretty well on the wheels. I have it on my bezels and rear bowtie with no issues. I picked mine up at a home depot.
Old 06-23-2012, 08:11 AM   #8
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Lowes $6 a can. You can wash it. If applied done correctly, it does not scratch or peel.
I pressure wash mine (on fan setting) with no problems.
If applied correctly, you should use about a can per wheel.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 06-23-2012, 08:19 AM   #9
ihaveacamaro
I like teeth.
Drives: #198
A guy in my neighborhood paid me to plastidip his wheels black. Here are the results. These are 24 inch wheels and I still only used 4 cans
Name:  Plastidip wheel.jpg
Name:  Plastidip wheel 2.jpg
Old 06-23-2012, 03:18 PM   #10
CharleyKahleys
Any tips on how to apply it? It would be my first time,
Old 06-23-2012, 03:25 PM   #11
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
check the DIY section
Old 06-23-2012, 04:55 PM   #12
NoynuR
Drives: 2008 M3 ESS Supercharged 650Hp
cheap way.....-__-. get them powder coated it will be around 500$ and it will be worth it. Not some cheap can bull shi*
NoynuR is offline   Reply With Quote
Old 06-23-2012, 05:43 PM   #13
Camaro Conv
Drives: 2011 Camaro SS Convertible
A little cheaper,
Thanks!
I am in the process of getting my stock wheels powdercoated in matte black. The dealer is doing it for me for $500 including dismount, remount, and balance. Plus the dealer guarantees it.
Camaro Conv is offline   Reply With Quote
Old 06-23-2012, 07:15 PM   #14
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Lots of good info here:
http://dipyourcar.com/
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
