Old 06-23-2012, 06:37 AM   #1
djamphi555
Drives: Camaro 2010
bad clutch mistake
Hello,
Did something really STUPID. I was at a busy intersection and here came my little gap. However, somehow I got all $%&#-up and really reved it, almost 4,000 and didn't disengage the clutch completely. So,... here comes the horrible smell of: damn, you suck man!!!
At the next stop light, I engaged the clutch and revved the engine to help cool down the flywheel, but the smell lingered all day.
Here is my question though, call me paranoid, but the car seems to shudder very slightly when I start off in 1st gear barely above 1,000RPM. Starts very smoothly if I am at 1,500RPM. Is it just me being paranoid and the car always did this? Or did I burn my clutch? The shudder feeling I remember from before, just not sure if it used to happen if I engage around 700RPM, because the car idles around 500RPM. Sorry long story.
How much gas do you usually give it in heavy slow traffic in first gear? Up to how many RPMs? Thanks.
djamphi555 is offline   Reply With Quote
Old 06-23-2012, 06:41 AM   #2
Brutal SS
Brutal SS's Avatar
Drives: 2019 Camaro 2SS 1LE
I think most of us have done this at least once.
Brutal SS is offline   Reply With Quote
Old 06-23-2012, 07:33 AM   #3
jd10013
Drives: 2012 camaro
I tend to give it more gas and shift around 3000 RPM's. seems to shift smoother.
jd10013 is offline   Reply With Quote
Old 06-23-2012, 07:45 AM   #4
nitrorcr1787
nitrorcr1787's Avatar
Drives: 2012 2SS
Hey we all get brain fade. It should be fine. A couple of nights ago I was on my way home, and didn't have the clutch fully in, and ground a pound of third gear. Oops....
To my brother Scott, Thank you for your gift. I would give it all back just to have you here again.
Scott N. 08/05/64 09/28/2010
nitrorcr1787 is offline   Reply With Quote
Old 06-23-2012, 08:06 AM   #5
cmb74656
cmb74656's Avatar
Drives: 2011 Camaro 2SS/RS CGM/BLI A6
Can't find 'em? Grind 'em.
Dan Wheldon (1978-2011)
MODS: RX Performance catch can, Jegs CAI, ZL1 grille, chrome license plate frame, GM locking gas cap, Defender Worx chrome DRL bezels, GM molded splash guards, Oracle LED side markers, DRLs, tag lights and reverse lamps, Technostalgia Rapid Fire tail lamps, Vitesse shift paddle extenders, MBRP cat back.
FUTURE: long tube headers, front splitter, slotted/drilled rotors, leather console and e-brake handle boot, remote fuel door and rear seat release, sway bars and bushings.
WISH LIST: Edelbrock E-Force SC, LS3 conversion
cmb74656 is offline   Reply With Quote
Old 06-23-2012, 08:44 AM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
The engine has so much torque that you can start out barely touching the throttle. You don't have to rev to go. Not in heavy traffic, but sometimes I start out in second for the fun of it.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-23-2012, 08:17 PM   #7
ChriSS
ChriSS's Avatar
Drives: Camaro 2SS/RS M6 Black and IOM
Dont worry about it man I have done it twice . One time I was being stupid and the other time I was on my way to a car show and I was at the top of a hill with a Hennessy car behind me, I was like there's no way I'm rolling back in to the front of that thing so I gave it a lot of gas and bearly let off the clutch to move forward.... then came the smell ..... Lol the car still seems to run fine.
ChriSS is offline   Reply With Quote
Old 06-23-2012, 09:17 PM   #8
Dr. Love
Drives: 2012
Originally Posted by djamphi555 View Post
Hello,
How long have you been driving a stick?
Dr. Love is offline   Reply With Quote
Old 06-23-2012, 09:18 PM   #9
Dr. Love
Drives: 2012
Not me. I have never had a clutch issue.
Old 06-23-2012, 09:57 PM   #10
Macater
Macater's Avatar
Drives: 2012 1SS/RS Sunroof, Con Pkg
I live around DC and I've found if you let the clutch out really slow you really don't have to get on the gas in slow traffic. I basically had to teach myself how to drive in the daily stop and go traffic. I was sweating bullets the first few weeks of owning it because I was afraid to stall it in middle of traffic.
Macater is offline   Reply With Quote
Old 06-23-2012, 10:31 PM   #11
dweeler
dweeler's Avatar
Drives: 2012 CRT 2SS/RS
Damn, I wish I was that perfect!
dweeler is offline   Reply With Quote
Old 06-23-2012, 11:28 PM   #12
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
How does revving the engine with the clutch pressed in cool off the flywheel?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 06-24-2012, 12:09 AM   #13
TwistedEnergy
TwistedEnergy's Avatar
Drives: 2010 IOM 2SS/RS
I do the same thing, in heavy traffic i leave it in first and don't even need to touch the gas at all, just let out the clutch really slowly. I love the torque on this car. @OP I've done the same thing in my driveway, and again on my uncles driveway and another time on a hill but the smell always went away after a minute or so. Like others have told me, I wouldn't be to worried about it, for smooth launches I've noticed between 1000 and 1500 RPM seems to be the sweet spot.
TwistedEnergy is offline   Reply With Quote
Old 06-24-2012, 12:35 AM   #14
Robert795
Robert795's Avatar
Drives: 2012 Camaro LS
Don't worry about it, the slightest slip on the clutch results in a burnt smell. It will go away.
Robert795 is offline   Reply With Quote
