06-24-2012, 04:56 PM | #1 |
Transmition temperature.
What is the normal transmition temperature on a magnacharged auto camaro?
Mine is sitting a little above 180, and I don't want to tear it up! |
06-24-2012, 05:16 PM | #2 |
Get a trans cooler, your trans will thank you for it.
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
06-24-2012, 06:29 PM | #3 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Here are a couple of decent references. They are slightly different but it gives you an idea of what to expect and set as a tranny temp target.
http://www.txchange.com/heatchrt.htm and this: Automatic transmission oil can provide up to 100,000 miles of service before oxidation requires replacement, at an operating temperature of 175° F. Above this temperature, the oil oxidation rate doubles with each 20° degrees F increase in oil temperature. DEGREES F MILES 175 100,000 195 50,000 215 25,000 235 12,500 255 6,250 275 3,125 295 1,500 315 750 335 325 355 160 375 80 395 40 |
06-24-2012, 09:41 PM | #4 |
Ghostly Unknown
Drives: Silver Ice 2010 SS/RS A6 Join Date: Oct 2008
I run a Long Trucool Max LPD4739 btu rating 45,000,It is one bad mofo,my car runs 135-145 degrees @80mph,and when I beat on it it'll get to 180-190,but quickly recovers,get that heat down or won't live,and get a good tune
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
