Old 06-26-2012, 11:04 PM   #1
ceyl
ceyl's Avatar
Drives: 2012 2SS/RS M6
3 Bar MAP Sensor
Any benefit to running a 3 bar map with FI rather than the stock map?
SLP TVS 2300, Kooks Long Tubes, Magnaflow 3" comp, BAP, Rotofab CAI, RX catch can, valve cover breather and 3.4" SC Pulley.
ceyl is offline   Reply With Quote
Old 06-26-2012, 11:11 PM   #2
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Depends on how much boost you plan on running, the stock sensor is fine for most, but only reads up to 12 or 13psi, anything above, its recommended you swap out for a 3bar
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 06-27-2012, 06:54 AM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Someone please pipe in If I'm wrong, but I believe the 3 bar map allows you to swap over to a speed density tune...
We are doing this to my car... It has what I'm calling ... gas coughs... or an intermittent hesitation cruising down the road, part throttle, and start up a gradual climb... I usually downshift and get into a higher RPM range to help...
I described it to my tuner/builder, he took it for a drive and came back and said we were going to use a three bar map and a speed density tune... If I understood him correctly, he said it gave him a lot more area to play with so the injectors would know what to do from idle, to WOT, and everything in between... Sounded illegal or something...
Again... A lot of this is still foreign to me... Last time I worked on cars at anything above a oil changing level was when you tuned a car with a screw driver and a stick, and read spark plugs and tail pipes...The only dyno we had was the butt dyno...
Old 06-27-2012, 07:55 AM   #4
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Yeah Robert at your power level with those turbos 3bar Sd tune is about the only way to go. SD tune takes ALOT of time datalogging.. smoothing out fuel etc..
Pyroboy has it right the stock Map sensor can only read so high so you need to swap after that to get exact measurement of kpa Etc..
JLE58 is offline   Reply With Quote
Old 06-27-2012, 10:38 AM   #5
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Exactly what they said
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
