![]() ![]() ![]() Drives: 2011 2SS/RS A6, IOM Join Date: May 2009
Tire Pressure Monitoring System-Inside or external monitors?
As I understand it there are two basic systems, one with internal sensors and the other doing external monitoring. Only reason I care is that using air and goop tire inflators ruins the internal kind so a flat cost you a new can of air/goop and $100- $110 for new sensors.
Am I worrying about nothing? |
the only time I would ever use the goop would be in an emergency. And that point to have to come back and spend 100 bucks just has to happen.
#3 | |
![]() ![]() ![]() Drives: 2010 2SS/RS Black Join Date: Mar 2009
I don't know if they are internal or external, but that would be really messed up if they were to be internal and GM supplies the 'fix-a-flat' with the SS'...
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure! Folding@home Stanford's Research DC Program. |
Not sure what has an external sensor, but everything I've worked on has the an internal sensor. Two basic types, a flexible threaded rubber valve stem and a hard composite valve stem. They both have their ups and down's, but I prefer the hard ones as long as something doesn't hit it and it cracks(which I've only seen happen once).
Edit: There is supposed to be some kind of sensor safe can of tire sealer, but I carry around a plug kit and jar of rubber cement in my cars. |
#6 |
BOD 5/28/09 #13485
Drives: 2010 Camaro 2LT RS Join Date: Jan 2009
They are the internal sensors that are in the wheels atached to the valve stem.
The "fix-a-flat" that comes in the SS's is OK to use. It will not harm the sensors.
#7 |
Thanks for the info
The "external sensors" somehow measure the rpms of the wheels so if a wheel goes down, it is somehow recognized and reported to the driver info.
I'm no expert so I really appreciate the info provided by the the posters on this thread. Glad to know their is a sensor safe inflator. |
#8 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
Not doubting you but what is your source of info?
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
#9 |
![]() Drives: CGM 2LT RS Join Date: Oct 2008
edit: i got different information from the mechanic at my dealer, which is why i ended up getting the spare. I was told the goop will destroy the sensor in the wheel and at that point both the tire and the sensor have to be replaced
#10 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
This sytem does not measure tire pressure.
#11 |
![]() Drives: 2010 Camaro 2SS RJT Join Date: Apr 2009
I do not like that we will not have a spare either.
All vehicles up to a certain weight are now required by law to directly measure tire pressure which requires a monitor to be installed inside the tire and wheel. Now using fixa flat has the potential to ruin a sensor. Fixa flat itself will not ruin a tire. Running around on low air pressure is generally what causes your tire to be unsafe. Usually fixa flat gives people a sense that it is ok to keep driving even if the tire is low and that is the problem. Using fixa flat is usually a messy problem for your tire guy and you should ALWAYS let them know you used it. OP that got a spare it would be nice if you could let us know if it fits over those Brembose. I would definatley order one to put in the car if they have one that will work. |
#12 |
![]() ![]() ![]() ![]() Drives: 2LT RS CGM Join Date: Apr 2009
no flats for me. thats my plan.
and usually if i have a flat is a slow leak, so if i air it up i should be able to get to a tire shop
