Old 06-29-2012, 10:59 AM   #1
blkevrythng
Drives: 112ssrsblk
Different oil?
If i have a cammed car, is there a better oil... Or even an oil additive that would be better han mobil 1?
blkevrythng is offline   Reply With Quote
Old 06-29-2012, 01:29 PM   #2
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
every oil is almost same, just a brand pref
Hellfighter is offline   Reply With Quote
Old 07-01-2012, 11:42 PM   #3
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
I have always used Mobil 1 75W90 gear oil plus you don't need friction modifier.
Just make sure you change it on time though.
Blueovalman is offline   Reply With Quote
Old 07-01-2012, 11:54 PM   #4
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
different, not differential
babytiger is offline   Reply With Quote
Old 07-02-2012, 10:01 AM   #5
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
Based on Ted's recommendation I'm running 10W30 Mobil 1. I also run about 7 quarts (at the low mark on the dipstick) per his recommendation. 4000 miles later and no issues.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 07-02-2012, 05:39 PM   #6
blkevrythng
Drives: 112ssrsblk
Why the low end?
Old 07-02-2012, 11:39 PM   #7
Blueovalman
GM engineering highly recommends that you use Mobil 1 5W30
synthetic motor oil and "5W30" is the correct weight motor oil
to use not "10W30" FYI.
Old 07-02-2012, 11:52 PM   #8
gotroost
gotroost's Avatar
Based on experience, I think Jannetty knows what they are doing. For the LS3, there are some cavitation issues running the oil too high.
2021 Crush ZL1 1LE
Old 07-04-2012, 12:54 AM   #9
Avenging Orange
Avenging Orange's Avatar
Guess it depends on what you are doing with your cammed car.......racing, daily driver, garage queen?
I know many are hung up on what GM recommends..........but its moslty to meet EPA standards and othe such government mumbo jumbo.
Yes, synthetics are super slick long lasting oils............but they also are not good penetrating oils.
If you beat your car up at the track, I'd suggest moving up to a 40wt.
But if its just the daily driver, I go to the track once a month car, then stick with your Mobil 1.
And if this is a 'I'm thinking about getting a cam' post, then I would suggest using a good old fashoned dino oil at the time of the cam install, and then what ever you want the next oil change.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 07-04-2012, 02:18 PM   #10
SC2150
M1 is good, Amsoil, and several others are a step above since M1 eliminated some of the antiwear properties a few years ago....Andy from Amsoil is a member here....check with him.
Old 07-05-2012, 02:46 AM   #11
Blueovalman
I think that Mobil 1 and Mobil 1 Extended Performance are both
excellent top notch high quality oil motors to use in your vehicle.
It's hard to argue that the people how build these LSX engines
highly recommend using Mobil 1 motor oil in their engines.
The Super Syn anti-wear techology is one of if not the best
anti-wear additives out there.I know that their are many benefits
from using Mobil 1 motor oil in your engine as I have used Mobil 1
for years and years.Nothing performs like Mobil 1 I belive with
outstanding wear protection and engine cleanliness,excellent
high and low temperature performance,excellent fuel economy,
helps prevent deposits and sludge build-up to enable long engine life,
and meets all GM's specifications.
Definitely do your own research and see for yourself the many
benefits of using Mobil 1 in your vehcile.
Mr. Clean
Old 07-19-2012, 05:32 AM   #12
Chang
Chang's Avatar
Drives: 2010 Camaro V6 LLT Rally Yellow
Wow, that was alot good words, no wonder why suspended.
I perfer AMSoil and Castrol Edge, heard about Redline and Royal purple are good as well. Just don't think Mobil 1 is the only "1" to go.
Chang is offline   Reply With Quote
