Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 07-01-2012, 05:43 PM   #1
baller3643
Drives: 2012 Summit White 2SS/RS
2012 2SS vs. 2010 Audi S5
My friend has an automatic 2010 Audi s5. I just got a manual 2012 Camaro 2 SS. I know that I have the power advantage, but will his AWD let him get the power down quicker? Both cars are completely stock btw.
baller3643 is offline   Reply With Quote
Old 07-01-2012, 06:08 PM   #2
8cd03gro
Drives: 2005 STi corn fed
You should have no problem. If I recall, the 2010 s5 has the 4.2 v8 that is also in the s4. Having a stock automatic in an awd vehicle is pretty poor for launching.
8cd03gro is offline   Reply With Quote
Old 07-01-2012, 06:19 PM   #3
08-G35s/6MT
08-G35s/6MT's Avatar
Drives: racecars
S4 would be a dead heat through the 1/4 mile.... they can pull 12's all day long because traction is no issue.
08-G35s/6MT is offline   Reply With Quote
Old 07-01-2012, 06:22 PM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Hmmmm... i would tend to disagree... While a 2.0x 60' is not all that great, it is when the track conditions are less than optimal and everyone else is struggling to pull a 2.2x!! Doesn't seem to matter the track conditions, i can consistently pull a 2.0x and if the track is prepped I'm at 1.9x...
scrming is offline   Reply With Quote
Old 07-01-2012, 06:40 PM   #5
8cd03gro
Yeah, that's not that quick compared to other awd cars you will see in the 12s though. Not knocking your ability, the auto just doesn't allow you to take full advantage of the grip awd gives you. Not as clear of an advantage over a rear wheel drive car other than consistency maybe. That's not to say it's a poor launch compared to cars in general, but not nearly the launch advantage offered with a manual. A stock auto with awd can brake torque and get a pretty solid launch. A manual with awd can dump the clutch at 5k and come out of the hole like a banshee. A nice loose stall setup can be insane with awd though, that's for sure.
Old 07-01-2012, 06:53 PM   #6
scrming
scrming's Avatar
Yeah, that's pretty poor when it comes to awd though. Not much of an advantage, if any, over a rear wheel drive car other than consistency maybe. That's not to say it's a poor launch compared to cars in general, but not nearly the launch advantage offered with a manual. A stock auto with awd can brake torque and get a pretty solid launch. A manual with awd can dump the clutch at 5k and come out of the hole like a banshee. A nice loose stall setup though can be insane with awd.
Got to remember the Brick with driver is 5185 pounds! LOL!
Problem with your dump the clutch method is hoping you can hook! At the track I doubt the Camaro is going to hook on street tires dumping the clutch at 5K! Test and Tune day, it might even be questionable on Drag Radials... The kind of "advantage" you are talking about is probably only going to happen with:
1) Drag Radials, maybe slicks... definitely not street tires!
2) Possibly suspension mods
3) Very well prepped track...
That's the beauty of AWD... I don't need those things! For example, I went out to Lapeer yesterday... so you know it was not well prepped! LOL! Had a 2.01 60' against a C5 Vette that had a 2.20 60'. I had a 1.95 60' against a 79 Z28 (manual tranny with sticky tires..) that had a 2.03 60'. I beat both cars while I was on ALL SEASON RADIALS, not even SUMMER tires!!! LOL!
So while I might not see a huge time advantage with my 2.0x, the AWD let me pull those times very consistently regardless of track condition and on cheap old ALL SEASON tires! At a minimum it makes me competitive against cars that normally would appear to be a lot faster!
Old 07-01-2012, 08:37 PM   #7
8cd03gro
You must have misread my post. . .
"A manual with awd can dump the clutch at 5k and come out of the hole like a banshee"
"That's not to say it's a poor launch compared to cars in general, but not nearly the launch advantage offered with a manual. "
Here I am talking about the launch advantage an awd manual car offers over a rwd car being much greater than the advantage an auto awd car offers.
I'm just saying there is a lot less to fear in the launch racing an awd car with a stock auto (not stalled) vs racing an awd car with a manual.
Old 07-01-2012, 08:47 PM   #8
scrming
scrming's Avatar
you are right, i did... mainly since we were talking Camaro (manual RWD) vs Audi (Auto AWD)...
Old 07-01-2012, 09:39 PM   #9
08-G35s/6MT
Drives: racecars
Generally, awd turbo cars suck out of the hole.... Unless you really abuse the hell out of it. The turbo lag slows/bogs it down off the line then the awd slows it down on the top end and add to the parasthetic drivetrain loss, so you put less power to the ground.
Old 07-01-2012, 11:17 PM   #10
8cd03gro
Yes, but he asked if the Audi would be able to put down the power quicker because of awd. I'm just suggesting that the advantage with an automatic is not nearly as great as some have come to expect when they hear the words, "all wheel drive" in a racing discussion. He isn't going to be launching out of the hole with 1.7 60's with the automatic, but will probably be within a tenth or two of the Camaro if the OP can launch. That's all I'm saying.
Old 07-01-2012, 11:23 PM   #11
8cd03gro
1. The 2010 audi s5 has a 4.2l v8
2. AWD turbo cars only suck out of the hole if you can't drive.
Old 07-02-2012, 06:19 AM   #12
scrming
scrming's Avatar
All I can say is "not mine!" LOL! Again, while 2.0x isn't blazingly fast, for a 2.5 ton vehicle it sure seems to surprise EVERYONE! I'm actually able to launch under boost, even with the stock torque convertor.... With the EcoBoost there is really no turbo lag! I have no idea about the Audi, but all I can say is the EcoBoost has proven itself time and time again at the track!
Old 07-02-2012, 06:26 AM   #13
scrming
scrming's Avatar
Yep, understood! My observations have been that most Camaros on street tires on a Test and Tune day are 2.2 to 2.4 60'. Occasional maybe 2.0 to 2.1... So if the OP is not completely familiar with running his SS at the track, the Audi will have a much easier time launching, and while it might not have as big advantage as if it had a manual, the Audi's AWD will certainly help level the playing field! IMHO!
Old 08-17-2012, 12:45 PM   #14
VaporNation
Drives: Camaro SS '12
camaro ss all the way
VaporNation is offline   Reply With Quote
