![]() Drives: She totaled it! Join Date: Jun 2010
Track tunning lower et
Alright guys want to know will track tunning lower my et at track.
What hptuner kit should i get for data logging. Is there one to log a/f and will a tuner be able to see if the trans is sliping? And what the stall is doing down the track locking or not locking? Thanks very much I am new to the whole data logging tuning stuff. And a side note i found a guy selling hp tuner pro on craigslist could this be used on my car? Thanks again guys |
#2 | |
Drives: 2010 Camaro Join Date: Feb 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
For logging AFR and external sensors you want the pro. You could use it on your car to log. To adjust anything you may need to purchase credits which are $100 per car. A new HPtuners setup for $650 comes with enough for 4 cars.
Nick
Corvette Z06 -1200ish rwhp |
Ok thanks will a tuner be able to see if the trans is slipping or flareing
![]() ![]() ![]() ![]() ![]() ![]() Drives: none Join Date: Aug 2011
You can log input and output shaft rpm.
#6 |
![]() Drives: 06 S/C GTO, 01 H/C/I Z06 Join Date: Dec 2009
Not sure on the 6L80 stuff but the older GM 4L65E would show you delivered engine torque as well as logging the input and output shaft.
Biggest deal with an L99 auto car that would help you lower ET would be adjusting the short shift in the stock trans calibration.
06 GTO - Maggie 112H (Stock Pullies), LPE CAI, SLP LMII Catback, suspension and Drivetrain STuff, Monster Stg 3 clutch, ETMC Stg II Cam, 60lb inj, IW 8" Lower, PRC .650 Springs, Trickflow Pushrods, Kooks 1 7/8 LTs, AIS WasherFluid inj, 530whp/537wtq SAE. Self Tuned via HPTpro
01 Z06 - Forged 347ci LS6 - H/C/I 460RWHP / 418 RWTQ (Self TUNED via HPTpro) ![]() |
