07-02-2012, 12:05 PM | #1 |
Drives: 2012 Corvette GS Join Date: May 2012
Want to make sure I'm getting correct tonneau cover
Hello all. A tonneau cover (boot) did not come standard with my 1LT, so I'm ordering one now. GM lists 3 different product numbers, but I am pretty sure the correct one for the 2012 model year is #22804475.
How will I know for sure that I have the newest 2012 model? I know that the coonectors to the 2 posts are elastic (not plastic). But is there anything else? I think I read that there are 2 foam blocks on each side that rest on the top...is this true? Are there any other nuances that I can check for to ensure it is a 2012? Any assistance will be appreciated. |
07-02-2012, 12:29 PM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Eliminate all doubt. PM Beckd at BeckyD@RodgersChevrolet.com
and have her check with Maureen. Sorry, I don't recall Maureens address. Maureen will get you the RIGHT info, and no doubt the best price. |
07-02-2012, 08:49 PM | #3 |
Drives: 2011 SIM 2SS/RS Vert Join Date: Jul 2011
And as a side note, the foam blocks were added mid-year for the 2011.
The early 2011 covers had clips instead of elastic, and had no foam blocks. The late 2011 covers had clips and included foam blocks (one on each side at the back). The 2012-> changed over to elastic straps instead of clips. |
07-02-2012, 09:01 PM | #4 |
@hdrdtd: I did and they got back to me very quickly; great folks...thanks for the tip. There is still a little confusion because of a change with the order number, so I'm sill relying on some help from forum members.
@gynatek: so the one I want for my 2012 is the one with both the elastic straps and the foam blocks (one on each side, at the back)? |
07-02-2012, 09:45 PM | #5 |
If ya get the one with elastic, ya should be covered. I'm not aware of further changes since the switch from the tabs to the elastic.
Mine is a late year 2011 model (GM Part number 22792013) and has the tabs and blocks. Yesterday afternoon was the first time I have had any concern about the cover flying off. I had it top down through the morning and afternoon and it was around 108 degrees out ... I think the heat made the materials stretch out a bit and be softer/more flexible. When I got out on the Interstate after leaving it parked for about 3-4 hours, it rippled quite a bit more than normal and I was "concerned". However, the cover remained firmly attached, to my relief. As for the part number of the 2012/2013 version, I am not certain and HDRDTD's suggestion is likely the best. |
07-03-2012, 12:10 AM | #6 |
Thanks alot gynatek!
07-03-2012, 08:53 AM | #7 |
I Got My Orange Crush
Drives: it like I stoles it... Join Date: Jan 2011
I have the late '11 version (plastic clips and foam blocks). After mine blew off once, I talked to the service dept about replacing it with the newer version (elastic loops). I was told that no matter which part number you order, the new design will be delivered. The old design with clips was discontinued.
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~ |
07-03-2012, 09:41 AM | #8 |
Drives: Camaro 2SS Convertible,blk,blk int Join Date: Mar 2012
And thanks to the clips that BODHI designed my 2011 tonneau will never fly off!
Gio |
07-03-2012, 10:37 AM | #9 |
@bodih
Thanks for the information bodih. I'll be getting it today or tomorrow from the dealer so I'll find out soon.
Gio Bella (next post) said that your modification helped. I found it but it looks like its for the older clips with the pull up tabs, so thinking it won't apply to the ones with the elastic loops. But it's good info regardless. Is this the thread that Gio is referring to? http://www.camaro5.com/forums/showth...66#post5114866 |
07-03-2012, 10:46 AM | #10 | |
07-03-2012, 11:26 AM | #11 |
Sounds like you have it dialed in! But I'm curious about the felt. Sounds like it goes in between the bottom of the tonneau and the top when its down...what's that for? Thanks.
07-03-2012, 11:49 AM | #12 |
Drives: 2011 2SS/RS white with IO vert Join Date: Jul 2011
mine was built in Feb 2011 and it has the foam blocks and tabs as well
07-03-2012, 11:52 AM | #13 |
Drives: 2011 2SS RS Vert Join Date: May 2009
How much are these? Are any dealers replacing these for free?
2SS RS, Triple Black Vert, Manual, Hurst Shifter. American Racing Headers, Roto-Fab CAI
07-03-2012, 12:06 PM | #14 | |
Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
