![]() Drives: 2011 Camaro Join Date: Jul 2011
Coilovers at stock height
Hey guys, I'm in the market for some coilovers but I need as much height as possible for winters in Alaska. I drive my car year round so I was just gonna slam it in the summer and lift it in the winter. Does anyone know of a coilover model that comes close to stock height without breaking the bank?
knows 2 facts about ducks
you can adjust the height of Pedders Xa coilovers to whatever you want. Heck, you could even go higher than stock if you wanted to.
Drives: Widebody 2013 Mustang GT Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
When adjusting the ride height, you have to adjust the spring perch upwards, up the shock tube itself. Of course you need strength to put it all the way as high as possible because you're fighting against the spring if you're doing the height adjustment while on the car, which makes it harder to get up high, but you can make them go up to about stock height if you have some muscle to get up there.
Drives: 2014 Z28 camaro Join Date: Sep 2009
The Pedders xa coil overs are adjustable to 1" above stock height and down 2" lower than stock height.The Pedders coil overs do not move the spring perch to adjust the height.The strut housing threads into the lower mount so you have the same amount of suspension travel up or down.
#6 | |
Drives: Camaro Justice Join Date: Jun 2007
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Don't forget, if you change the ride height you'll need to get an alignment, or should anyway.
#8 |
Awesome thanks for all the help guys!
#9 |
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Exige, Miata, Ghia Join Date: Jun 2011
Just a little bit of advice. GREASE UP THE THREADS every season. You WILL NOT have fun trying to adjust them seized up.
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2015 ZL1 Join Date: Aug 2011
I just got an alignment today at discount tire center and paid for the lifetime alignment so now I can adjust ride height on my coilovers as much as I want. Also they said they would set me up for track days and put it back when I was done. Great bargin for $189.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
#13 |
This is a great tip. For coilover users in areas of snow/heavy rain I recommend cleaning up the threads after each season. For users in good weather conditions every so often works just fine.
