Old 07-07-2012, 01:38 PM   #1
Mrose
Mrose's Avatar
Drives: 2012 ZL1 Victory Red !!!!!!!
Stabilitrack lite came on !help
I was down at MIS speedway and the stabitrack lite came on. does anyone remember didnt some else post this problem did a search was unable to find anything on it.
ZL1 Current Status:6000 #1251
1000 Initial Order 11/28/2011 -
1100 Order accepted at dealer: 11/28/2011 - QBDTB8
2000 Order accepted by GM: 04/23/2012
2500 Order preferenced. Pulled to the production system 4/24/2012
3000 Accepted By Production Control: 04/25/2012 - TPW 05/07/2011
3100 Sequenced: 05/03/2012
3300 Scheduled For Production:5/4/2012
3400 Broadcast: 5/5/2012
3800 Produced: 5/11/2012
4B00 Available To Ship car is bayed: 5/13/2012
4200 Shipped: 5/30/2012
5000 Delivered To The Dealer: 6/5/2012
6000 Delivered To Customer: 6/6/2012
Mrose is offline   Reply With Quote
Old 07-07-2012, 01:47 PM   #2
DangerZL1
Drives: 2023 Black ZL1 Auto
Theres another thread in this forum titled Service Stabilitrack light came on today. So, you're not alone. You'd think with all the track testing GM would have caught this.
DangerZL1 is offline   Reply With Quote
Old 07-07-2012, 01:55 PM   #3
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
My stabilitrak light has come on 3 different times all for different sensors.... go get it checked
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 07-07-2012, 02:09 PM   #4
Envy
Bully Proof
Envy's Avatar
Drives: C5 COTW 1/31/2011
Not sure whether this will help because I don't know if your service stabilitrak warning came on and stayed.
I was having a similar problem and I was seeing the "Service Stabilitrak" message on my DIC on a regular basis at start up but it never stayed on very long. So I started a thread on another site and found out many other people had the same complaint so here's the info that helped me solve the problem...
Originally Posted by rrings
Service StabiliTrak Message Displayed at Startup
By Blog Post on May 1, 2011 2:24 PM | No Comments
A 2010-11 Camaro may have an intermittent Service StabiliTrak message in the Driver Information Center (DIC) only at startup, and then the message will disappear within seconds of starting the engine. This message is displayed during the bulb check of the other instrument cluster indicators. This message will not remain on and no DTCs will be stored in the Electronic Brake Control Module (EBCM).
This condition will occur only under specific sequences of ignition switch operation. For instance, the driver may quickly flick and release the ignition switch during Start/Crank mode. After the ignition switch is released and the engine starts, the DIC Service StabiliTrak message may then be displayed. The condition may not occur each time this ignition switch sequence is performed.
If no EBCM DTCs are stored and the Service StabiliTrak message is displayed only at startup for a few seconds, then no repairs should be performed.
Engineering has identified the condition and has verified it is normal under this specific ignition switch sequence of operation. A revised calibration is available in TIS2Web. No parts should be changed to resolve this concern.
And here's my final post on the thread...
Originally Posted by Envy
Thank you for your post! I wanted to follow-up on this thread because I took note of the post above and I had been very guilty of "quickly flicking and releasing" the key in the ignition. Since reading this I have slowed down and been very careful when I turn the key and I haven't seen the message since. So I'm not worried at all anymore...problem solved.
While many dealership service departments are replacing sensors for this complaint...it is absolutely not necessary unless the service stabilitrak warning comes on and stays on in the DIC.
Envy is offline   Reply With Quote
Old 07-07-2012, 02:41 PM   #5
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
They intentionally programmed it this way as this is part of what the PTM system does. Protects an inexperienced driver. In PTM 1-3 the StabiliTrak is still turned on so if you take your car out on a track with a high inclination its going engage the protection system and set a code. In PTM 4-5 or "off" there won't be an issue.
RoketRdr is offline   Reply With Quote
Old 07-10-2012, 09:53 AM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
On page 9-35 in your owner's manual it states:
StabiliTrak® System
The vehicle has an electronic stability control system called StabiliTrak. It is an advanced computer controlled system that assists with directional control of the vehicle in difficult driving conditions. StabiliTrak activates when the computer senses a discrepancy between the intended path and the direction the vehicle is actually traveling. StabiliTrak selectively applies braking pressure at any one of the vehicle's brakes to help steer the vehicle in the direction which you are steering.
If there is a problem detected with StabiliTrak, a SERVICE STABILITRAK message displays on the DIC and the StabiliTrak/TCS warning light on the instrument panel cluster comes on. When this message and warning light display, the system is not operational. Driving should be adjusted accordingly.
I hope this information was helpful!
Old 07-10-2012, 11:23 AM   #7
Mrvnmartian
Drives: 2010 SGM 1LT (Manual)
There are plenty of posts about this message.
StabiliTrak® System
No, this wasn't helpful. There is a PIC that the dealership should do a diagnostic on the EBCM. The PIC # is #PIC5432A: Service Stabilitrak Message Displayed At Startup - (Apr 28, 2011). I am at work and unable to load the doc, but you should be able to do a search on this in google or any other search engine.
Mrvnmartian is offline   Reply With Quote
Old 07-10-2012, 04:54 PM   #8
Mrose
Mrose's Avatar
StabiliTrak® System
I dont condsider driving around a 2mile oval dificult driving conditions At 65 mile an hour. Two of five zl1 had this same problem so why didnt all five encounter the service Stabilitrack message. I simple took the car in and had the code cleared. SO please explain why this happens on only two cars and not all they were parade laps for god sakes under ideal conditions except fot the 103 deg temps
Old 07-10-2012, 09:09 PM   #9
Blueclyde
Drives: 2023 ZLE
OP, I was the other one at MIS that set the light. Did you have PTM activated? I did. I cleared the code myself. No biggie. I'm sure it was the 18 degree banking. That was not a normal track occurence. These cars really aren't meant for high banked super speedways.
Blueclyde is offline   Reply With Quote
Old 07-10-2012, 10:36 PM   #10
rickadu
Drives: '03RamDiesel '06TBlazerSS, ZL1 #772
I was also at MIS that day and had no light issues, but had a great experience.
rickadu is offline   Reply With Quote
Old 07-11-2012, 03:51 PM   #11
Mrose
Mrose's Avatar
It was very cool and no i was driving in sport mode 2 I didnt go into ptm. I had the code cleared also no worries just funny how two of the five ZL1's there had an issue with the Service stabilitrack but not all of them. Pm me sometime we will make the trip down to D town for a cruz with the 5gen club some nite . Mine sure felt at home on the super speedway i must admit
