Old 07-10-2012, 12:22 AM   #1
Camaroowner77
Camaroowner77's Avatar
Drives: The Red Menace
RPI stealth splash guards?
Hey guys has anyone used the RPI designs stealth splash guards? I have the GM splash guards and want to switch them out for something less noticible. Do they protect as much as the GM guards?
Camaroowner77 is offline   Reply With Quote
Old 07-10-2012, 06:07 PM   #2
Camaroowner77
Anyone?
Old 07-10-2012, 06:10 PM   #3
mycamaro2011
mycamaro2011's Avatar
Drives: 2010 Camaro 2LT Victory Red
I bought them and havent installed them yet.
I just dont think they are goin gto fit on my car with the factory GFX package even tho they claim it does
mycamaro2011 is offline   Reply With Quote
Old 07-10-2012, 07:50 PM   #4
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
I have them. They work as intended. You barely notice them. I like them.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 07-10-2012, 10:54 PM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I have them on mine, should have been my first purchase. Gills are chipped to hell before installing them.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 07-11-2012, 12:33 AM   #6
Camaroowner77
Do they protect as much as factory?
Old 07-11-2012, 12:34 AM   #7
Camaroowner77
The GM guards I should say
Old 07-11-2012, 12:37 AM   #8
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I would like to know this too especially when I'm getting the factory gfx
Lil' Nasty is offline   Reply With Quote
Old 07-11-2012, 01:35 AM   #9
Dizzy82
Dizzy82's Avatar
Here they are installed on my car. As far as I know they provide the same coverage without standing out as much as the OEM ones. I don't believe the OEM splash guards are compatible with the GFX kit.
Old 07-11-2012, 08:52 AM   #10
PIPE
Hating prius's since 1997
PIPE's Avatar
Drives: 2010 Camaro 2SS/RS (JENNA)
ZL1 splash guards all the way. They work and actually are less noticeable then the RPI ones.
PIPE
PIPE is offline   Reply With Quote
Old 07-11-2012, 09:05 AM   #11
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I have the RPI splash guards in the front and ZL1 splash guards in the rear. The mounting of the RPI rear guards is junk, that's why I went to the ZL1 rear guards. When installing the RPI's in the front, discard the metal clip they send and use double sided tape ( I used 3M ) to secure the upper part of the splash guard to the fender.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 07-11-2012, 09:16 AM   #12
fargomike
The Dude Abides
fargomike's Avatar
Drives: Black 2SS M6
Ed M.
Was there any drilling involved with the ZL1 splash guards ?
2010 Black 2SS/LS3/M6 Kooks 1 7/8 Ceramic Coated Headers, Borla ATAK CB , JRE Tune , Halltech Yellow Jacket CAI ,VMax Ported TB, PFADT Coilovers,Forgestar CF5's Textured Gunmetal w/Nitto Invo's 275/315 ,Hurst Billet Plus 2 Shifter AAC P13W Plasma LEDw/DRL Harness ,30% Tinting,
fargomike is offline   Reply With Quote
Old 07-11-2012, 09:38 AM   #13
NewDivide
NewDivide
NewDivide's Avatar
Drives: SW '13 1SS/RS & '12 Honda CRV
Ed M.
Exactly what he said, to the letter.
NewDivide is offline   Reply With Quote
Old 07-11-2012, 09:40 AM   #14
The Stig
knows 2 facts about ducks
The Stig's Avatar
Ed M.
do the ZL1 rear splash guards work with the GM GFX rear diffuser?
Click to view my build thread
