Old 07-10-2012, 09:34 PM   #1
Runawayhacker
Runawayhacker's Avatar
Drives: 2017 Camaro 2SS
Required post-mod tweaks?
I remember seeing somewhere that after installing a CAI, you need to have the dealership re-program your Camaro to adjust to the change. Perhaps tweaking the mass airflow sensor? Is this true?
And while we are here, my clutch doesn't feel quite as "tight" as it did when it was new. I only have 4000 miles on it and am an experienced stick driver. I read that the hydrolic clutch shares the same reservoir with the brakes. I've noticed some leakage on top of the reservoir container. Not major, just enough to cover the top and make it greasy. Is there anything I can do myself to maintain this or should I have the dealer take a look at this?
Depending on the answer, I may look at adding a separate reservoir. Anyone already have one? Is it worth it?
P.S. Sorry for the mixed bag of questions. Felt like they weren't major enough to start a thread for each.
Runawayhacker is offline   Reply With Quote
Old 07-10-2012, 09:37 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
No that is not true. I highly suggest getting a separate clutch fluid reservoir, it's a very cheap mod and completely worth it.
Click to view my build thread
Old 07-10-2012, 09:38 PM   #3
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
I can answer for the intake. YES tune is required, you changed the fuel/air mix ratio and that must be fixed by a tune.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 07-10-2012, 09:39 PM   #4
The Stig
The Stig's Avatar
This is incorrect. SOME intakes require a tune (example is the tune version of the Vararam intake) but most of the intakes on the market do NOT require a tune.
Old 07-10-2012, 09:45 PM   #5
Runawayhacker
Ok, since it is model specific, I suppose that the K&N Typhoon CAI for the SS does not require tuning. Is that right?
Old 07-10-2012, 09:45 PM   #6
LADYBMBLEBEE
Drives: 12 2SS/RS Transformer, 11 2LT/RS
I have a Cold Air Inductions CAI on my 2012 L99 no tune was necessary.
LADYBMBLEBEE is offline   Reply With Quote
Old 07-10-2012, 09:46 PM   #7
The Stig
The Stig's Avatar
correct. It does not require a tune.
Old 07-10-2012, 09:48 PM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Old 07-10-2012, 09:49 PM   #9
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
i bought that second reservoir kit for the clutch from a member here on the site (can't remember his name). just haven't gotten around to install it.
can anyone tell me why it's such a good thing for they clutch and brakes to have different reservoirs?
Alain is offline   Reply With Quote
Old 07-10-2012, 11:02 PM   #10
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
Clutch dust makes it into the fluid. Don't ask me for the source. I didn't believe it either. I thought it was a sealed system, but it makes it in there. Clutch dust in the hydraulic fluid ruins o-rings in the clutch actuation cylinders. Having a second, smaller reservoir makes changing the fluid frequently easy. This prevents dust buildup and lengthens clutch life. It also keeps clutch dust out of your braking (safety) system. There's a huge thread on it somewhere on this site (can't search from my phone).
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 07-10-2012, 11:33 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
To answer the OP's first question properly it depends on the MAF you have and the match of bolt ons.
My very first mod was a CAI Inc intake. Worked great. A while later i added a ported TB and it too worked great for a short time. All of the sudden my car started bogging down badly at WOT and generally performing like a dog. Went over everything multiple times and FINALLY i discovered the problem.
My factory MAF was a "weak" one. Bought a "strong" one from Chase at Apex and poof. All my issues went away and never returned. This is more than a year later and still going strong. (I tested my old MAF in a buddies stock SS and it worked just fine. So, wasn't faulty just weak and unable to properly work with the combined added airflow pattern)
While my car does not have a tune and did not need one. I did in fact need to change out my MAF for a stronger one once i coupled that ported TB along with the CAI.
Not everyone experiences this but, i sure did.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-10-2012, 11:47 PM   #12
ss/rs-matt
Drives: 2015 ZL1
No, a CAI to not NEED a tune but if you want the most out of it, it does.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
ss/rs-matt is offline   Reply With Quote
Old 07-11-2012, 07:50 AM   #13
Higgs Boson
Perpetual Order
Drives: indeed
It isn't clutch dust. It's burned fluid. The slave cylinder being where it is on these cars, Corvettes, and 4th gen camaros has made it a very common issue since the late 90s. The fluid gets really hot and it makes the pedal stick or return slowly.
But you are right, the Corvettes come with a separate reservoir stock and you can just change out the fluid from the top on a regular basis since bleeding the system is a pita without a remote bleeder.
Higgs Boson is offline   Reply With Quote
Old 07-11-2012, 08:59 AM   #14
Birm
Birm's Avatar
Drives: Florida Speed & Power
You are incorrect, some systems require a tune and they are specified by the manufacture.
A tune however WILL help maximize performance gains.
To reset your MAF and everything else just unplug your battery, wait a few and hook it back up. It will automatically reset/relearn.
Birm is offline   Reply With Quote
cai, clutch, mod, reservoir
