Old 07-19-2012, 09:52 PM   #1
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Question about manifold and plenum spacers with strut tower brace.
I was wondering what combination of manifold and plenum spacers will fit under a BMR strut bar? I will evntually do booth a strut bar and spacers but will the mace 25mm and 12 mm spacers fit under the bar? Or will only the 3/8 black ice and 1/2inch plenum fit? or will I have to forget about the plenum spacer if I get the strut bar?
Thanks for the help.
Old 07-19-2012, 10:03 PM   #2
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
I have the 3/8" spacer and the BMR brace there is less than 1/4" between the plenum cover and brace. I'm pulling my brace off to be able to install the plenum spacer.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 07-19-2012, 10:17 PM   #3
menendez1293
Wow that is less clearance than I thought. Guess I will forget about the brace. The gains from the spacers will be more signicant than that of the brace.
Thanks for the answer
