Old 07-21-2012, 07:31 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Plenum Spacer Question
Hey guys, does anyone know the parts numbers for the factory plenum gasket and that x-wing thing? I want to use all gaskets and not worry about the gasket maker issues.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 07-21-2012, 09:14 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Base gasket for intake manifold only is 1259-0958.
A kit containing same base gasket, X-gasket, and plenum lid gasket is
1261-5968.
Old 07-22-2012, 05:12 AM   #3
JohnZ
JohnZ's Avatar
Thanks Ventmaster! I wish I knew about this kit earlier, I already bought the manifold gasket. I just need the other 2 (plenum gasket and x-wing).
Old 07-22-2012, 06:04 PM   #4
Chang
Chang's Avatar
Drives: 2010 Camaro V6 LLT Rally Yellow
Wondering about the 2nd x-wing, is it necessary?
Chang is offline   Reply With Quote
Old 07-22-2012, 06:30 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
No I run without mine
Lil' Nasty is offline   Reply With Quote
Old 07-22-2012, 09:05 PM   #6
Chang
Chang's Avatar
Did u use a 2nd plenum gasket?
Old 07-26-2012, 05:16 PM   #7
Chang
Chang's Avatar
I bought the lower IM gasket 1259-0958 already. Trying to buy the plenum gasket and X-wing gasket separately but really can't find anywhere sells them separately, so I ended up bought a set of gasket kit 1261-5968 which contains another lower IM gasket. Anyways, i guess i will use NEW lower IM gaskets both bottom and top of the Black Ice-o-lator.
Old 07-26-2012, 06:56 PM   #8
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
I deleted the x-gasket, kept the plenum square gasketon simply because It doesn't cause a problem like the x-wing and it's easy to , Installation: plenum cover, plenum square gasket, rtv or gasket maker to the plenum spacer, apply 4 washers onto the center most four holes with rtv or gasket maker apply to manifold, tighten everything up AND MAKE SURE the four washers don't fall into the block!! (that's why I didn't use the x-gasket, fear of knocking the washer into the block)
