Old 07-25-2012, 12:07 PM   #1
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
ZL1 Grill; CF hydroed ACS T3 Ports
Finally finished painting my ZL1 grill (GMPartswarehouse) and installed it along with Trackspecmotorsports supplied T3 ports. They were one of
only two vendors I could find who had a set that were
CF hydro-dipped. The other vendor charged $30 shipping
so Trackspec it was!
The LED DRL replacements are from Phasetek (also made by ACS)
I did not want to pay $100 for ACS' mesh. I had a big roll of diamond mesh I got at an arts/crafts store, cut out a piece to fit, plasti-dipped it black, and glued it to the backside of the ports.
I saw that the LEDs were coming loose when I uploaded the picture from the camera, that sucks but easy fix.
Thanks to John at Track Spec Motorsports for letting go of their last set of carbon fiber ports (had to talk him into it). He mentioned they might make more if the demand was there.
ZombieEatsYou is offline   Reply With Quote
Old 07-29-2012, 10:14 AM   #2
SNK
SNK's Avatar
Drives: 2010 2LT...Black
Are the LED's wired so they work as the daytime running lights or are they on a separate switch? Great work also!
SNK is offline   Reply With Quote
Old 07-29-2012, 11:52 AM   #3
XxManontheMoonxX
Drives: 2012 1SS/RS
What grill is that?
XxManontheMoonxX is offline   Reply With Quote
Old 07-29-2012, 12:01 PM   #4
XxManontheMoonxX
Drives: 2012 1SS/RS
Originally Posted by XxManontheMoonxX View Post
What grill is that?
retract that question its stated in the title lol
Old 07-29-2012, 12:29 PM   #5
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
I like the CF look on the ports.
bumblebeecamaro is offline   Reply With Quote
Old 07-30-2012, 04:25 AM   #6
ZombieEatsYou
The LEDs are a direct replacement for DRLs. You actually snip off the OEM DRL harness and install a replacement harness (supplied) for the LEDs.
Old 07-30-2012, 04:29 AM   #7
ZombieEatsYou
Agreed. Very rare, could only find two sources: Trackspecmotorsports and this on ebay. Trackspec was cheaper though.
Old 07-30-2012, 04:49 AM   #8
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Looking great
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 07-30-2012, 06:23 PM   #9
Jermola23
Drives: 2011 black camaro
so you reconnect the leds to your drl wires? can you also have them to a switch so you can turn on yourself?
Jermola23 is offline   Reply With Quote
Old 07-30-2012, 10:25 PM   #10
v6
Drives: 2012 45th 2LT RS
can you have the LED's on with your halo's at night? what if you buy a different harness?
v6 is offline   Reply With Quote
Old 07-31-2012, 04:32 AM   #11
ZombieEatsYou
I haven't seen the harnesses that keep the DRLs on all the time so am not sure. With these LEDs you have to cut off the existing DRL "slot" harness and connect to a new two-pin harness (below). If the DRL conversion harness is supposed to be plugged into the existing OEM harness then it won't work with these LEDs since the female socket of the OEM harness is now replaced with this male 2-pin connector.
