Old 07-29-2012, 11:47 AM   #1
2Muchmark
2Muchmark's Avatar
Drives: 2013 2SS RS 1LE
Send a message via ICQ to 2Muchmark Send a message via MSN to 2Muchmark Send a message via Skype™ to 2Muchmark
Stupid question from a non motor head - Lock-up Torque Converter vs LSD
So I'm considering buying another Camaro and was poking around on the GM order page when I noticed this. If I choose automatic transmission, I have to give up Limited Slip Differential. Is this item more or less replaced by the Lock-up Torque Converter? Or are these 2 completely different things and I now look like a total n00b?
2Muchmark is offline   Reply With Quote
Old 07-29-2012, 12:00 PM   #2
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
I think that's a weak move by Chevy.
And all modern automatics have a lock up convertor.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 07-29-2012, 12:38 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
i8ts just a goof up on the part of the Chevy website.....ALL V8's have a limited slip Diff. only the V6 Manuals have it.
Old 07-29-2012, 12:52 PM   #4
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
cool! I didn't know I had lim slip dif
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-29-2012, 03:37 PM   #5
jd10013
Drives: 2012 camaro
neither did I. exactly what the hell is it
I'm familiar with the term, but not being a gear head I only have a rough idea of what it does and what the benefits of it are. anybody care to help?
jd10013 is offline   Reply With Quote
Old 07-29-2012, 03:45 PM   #6
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Basically what it does is when the drive wheel starts to slip on ice, water, dirt, etc, the differential locks and transfers power to the other wheel.
Bhobbs is offline   Reply With Quote
Old 07-29-2012, 03:48 PM   #7
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
This might help you understand a bit more about differentials and the different types:
http://www.howstuffworks.com/differential.htm
A bit of reading, but how else would a non-gear-head learn the basics?
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 07-29-2012, 03:58 PM   #8
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
GM used to call it 'positraction'. The simple definition back in the day was "transfer grip to the tire that slips". There's a clutch pack in there
Ever see the rubber marks put down by performance cars? The pair of tire marks is from a limited slip. The single mark is from an 'open' type. Used to be called a 'one legger' burnout.
One tangible effect is that the back end of your car can thrash around like a shark making a kill when you're really burning them up, with posi.
It's not a 'free pass' on loose dirt or ice, either, even though the description seems to indicate it makes that type of surface a snap
A limited-slip tries to drive both rear tires. It still has some slip by using clutches because when cornering the outside tires turn faster than the inside tires.
This is a nice description
ChrisBlair is offline   Reply With Quote
Old 07-29-2012, 06:24 PM   #9
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
A torque converter lock-up I believe means the fins in the TC lock together and the trans becomes "like" a manual in a single gear where the engine is driving the gears directly through the input shaft versus when the TC is unlocked, it uses fluid pressure to drive the input shaft, which drives the gears.
Everyone already nailed the limited slip diff (LSD) definition.
It should be noted that LSD is different from a locking rear which can be electronic, mechanical/air, or inertia-lock (G80 rear end from GM) where the diff locks the rear wheels together when slippage is sensed. It unlocks at a predefined speed or when both wheels have traction. These are different from a "spool" --it was common in early racing to weld the rear spindles together inside an open differential so that both wheels were driving the car, which is important in hard cornering, especially if you've got one wheel off the ground.
So, there's OPEN, Limited Slip, Locking, and a Spool. You now have the fundamentals to imagine the different types of differentials and how they work
Oh, last thing...Chrysler also developed a neat feature for the open differentials on the base Wrangler. Whereas the high-rent models like the Rubicon come with manual locking front/rear diffs, the base wrangler has open differentials front and rear. It means the rig is effectively two-wheel drive (one front, one rear), making it almost useless in technical 4-wheeling.
So, because Wranglers already come with EBD (electronic brake force distribution), they made an additional feature called "Brake-lock differential". It's an open differential. When one wheel slips, as sensed by the traction control system, it can use the electronic braking module to apply the brake fully at the slipping wheel so that the open diff transfers power to the wheel that has traction. It's an ingenious idea, and basically added programming to equipment that's already on the rig since the module is used by the stability/traction programs. There's debate whether Limited Slip or Brake Lock is more useful in slick situations or technical 4-wheeling.
1BADLS3 is offline   Reply With Quote
Old 07-29-2012, 08:18 PM   #10
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Originally Posted by Comrando View Post
An open differential drives the easiest to spin rear tire.
The open rear-end is considered safer because driving both tires when they slip causes the rear of the car to move sideways. Driving only one tire allows the non-driven tire to retain traction and the rear won't have the same tendency to spin.
Its like a posi traction. I would be all over the place if I didnt have it because I spin my wheels pretty easily even with T/C on.
shrinkdoc is offline   Reply With Quote
Old 07-29-2012, 09:45 PM   #11
squat
Drives: 2011 Dodge Charger
This really old video gives the best explanation of a differential and what a limited slip would do for you. It's kind of annoying that the technology for this is 80 years old and it's still not standard on all cars...
http://youtu.be/yYAw79386WI
If anyone knows how to embed that into a post please do.
2011 Dodge Charger
squat is offline   Reply With Quote
Old 07-29-2012, 10:46 PM   #12
two_wheel_mayhem
Old 07-29-2012, 10:47 PM   #13
two_wheel_mayhem
Two reasons, cost and fuel mileage.
Old 07-30-2012, 12:36 AM   #14
squat
How would limited slip effect fuel mileage?
Also, thank you for embedding the video, how did you manage to do it?
2011 Dodge Charger
