Old 07-29-2012, 11:56 AM   #1
jbotta
jbotta's Avatar
Drives: Camaro ZL1
AFTER BREAK IN, THEN 2 TRACK DAYS (road course) the zl1 motor really came alive
now after racing the z, the car seems to be so much better, driving around now it puts the power down so much better, nap time is over the beast woke up from a break in nap, I can tell a big differance from brand new till now, 2 track days the tires and breaks look good,
THE MOTOR REALLY COMES ALIVE!!!!!!!!
jbotta is offline   Reply With Quote
Old 07-29-2012, 12:00 PM   #2
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
Did you change your brake fluid prior to tracking ??
If not, Any issues at all with fade using stock fluid ?
AZ-ZL1 is offline   Reply With Quote
Old 07-29-2012, 12:09 PM   #3
jbotta
jbotta's Avatar
Drives: Camaro ZL1
super blue dot 4 going in this week have had 2 oil changes already this saturday getting diff fluid changed, had some break fade at the end of my track sessions. it was 98 outside the last track day, so far the z has been great, next track day in aug with better break fluid will see if we still get break fade.
Old 07-29-2012, 12:12 PM   #4
jbotta
jbotta's Avatar
Drives: Camaro ZL1
They should put better break fluid in from factory, this is truly a track car, dot 4 to the rescue.
Old 07-29-2012, 07:06 PM   #5
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Good to hear! I've always wondered why they don't use dot 4 on performance vehicles?
sammyv is offline   Reply With Quote
Old 07-29-2012, 08:23 PM   #6
97SS
Drives: 1997 Camaro SS
Good to hear! I laugh, when I see someone more worried about if the dealership left all the factory plastic on, or if they installed the front plate (won't mention names). This is where your true value is pleasured with these vehicles (imo), and why GM invested a lot of moola into this program. In the end, you only live once!
There was a guy at the last BW track event, with a black ZL1, breaking it in - at the track. No joke!
97SS is offline   Reply With Quote
Old 07-29-2012, 11:36 PM   #7
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Thanks, that'll be next on my list prior to a track here in Phoenix, after we get to sub 100's.
Old 07-30-2012, 08:12 AM   #8
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Wow, any catch on the VIN, i'd hate someone here buying it later on and not getting what they expect, I myself have less than 100 miles to go to finish my break in.
Bet you can't wait for some cooler weather to bring out some more HP!
mmarx82 is offline   Reply With Quote
Old 08-16-2012, 02:30 AM   #9
X25
X25's Avatar
Drives: '16 C7 Z51
How high were the engine oil temps during the track session? I am about to decide if I should get a ZL1 to replace my Grand Sport, and I really need to learn about its track performance.. I don't want to cook and change the oil after every event
X25 is offline   Reply With Quote
Old 08-16-2012, 02:32 AM   #10
X25
X25's Avatar
Drives: '16 C7 Z51
From Autoblog:
For the most part, we tend to shy away from forced induction on the track as it generates massive amounts of heat. We always seem to run into problems at these hot Southern California desert venues. The Camaro ZL1, despite a liquid-to-liquid engine oil cooler identical to the system on the Corvette ZR1, showed signs of stress after several relentlessly long and hard runs in the 100-plus degree conditions. The oil temperature, normally in the 200-degree range, slowly crept up past 300 more than once and the ZL1's self-preservation mode kicked-in. Rather than risk tying up a hot track with a hampered car threatening "limp mode," we pulled into the pits and opened the hood to let things cool down..
http://www.autoblog.com/2012/08/08/2...-review-video/
Old 08-16-2012, 06:24 AM   #11
jbotta
jbotta's Avatar
Drives: Camaro ZL1
temps where all ok
Old 08-16-2012, 02:52 PM   #12
X25
X25's Avatar
Drives: '16 C7 Z51
temps where all ok
What temps did you see?
Old 08-16-2012, 02:59 PM   #13
Russell James
Russell James's Avatar
I wouldn't base a car decision on that. If you are going to be doing real long hot lap sessions, just put a better oil cooler in.
Old 08-16-2012, 03:05 PM   #14
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
jbotta have you added the Catch Can? Curious... (Rx?)
htron50 is offline   Reply With Quote
