Old 07-30-2012, 02:32 AM   #1
ImperialSScamaro
Im a noob
ImperialSScamaro's Avatar
Drives: Black 2016 1SS
noob header question
i know everyone hates the stock exhuast but is it possible to keep the stock exhaust and add some bigger better headers
ImperialSScamaro is offline   Reply With Quote
Old 07-30-2012, 02:55 AM   #2
TSSUNAMI
It was ninety nine cents!
TSSUNAMI's Avatar
Drives: 2014 Jeep Wrangler
Yes, you can remove the stock manifolds and cats, there are several brands of aftermarket headers that will mount up to the stock connection pipes.
TSSUNAMI is offline   Reply With Quote
Old 07-30-2012, 02:59 AM   #3
ImperialSScamaro
Im a noob
do you get the same performance gains as if you changed the mufflers or just went to straight pipes? does the stock mufflers sound that bad?
Old 07-30-2012, 03:11 AM   #4
ImperialSScamaro
Im a noob
what about keeping everything stock but only changing the headers?
Old 07-30-2012, 04:00 AM   #5
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
I run headers hi flow cats in to oem cat back and it's perfect no droan and barks nicley, still quiet at idle except i run a rough idle bump stick and gives a bit more aggressive idle tone with some rock n roll
Impo cat back afternarkets ill provide add db's to idle and over all tone/ sound but minimum performance gains and potential droan at cruiz rpm 1500 - 2000 rpm
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 07-30-2012, 05:08 AM   #6
ImperialSScamaro
Im a noob
so basically no performance gains?? just changes the sound??
Old 07-30-2012, 05:17 AM   #7
RogerBzSS
RogerBzSS's Avatar
The perfomane gain including added sound is all in the headers hi flow cat combination and tune
But tune comes wirh a price of voiding powertrain warranty, not the headers / cats
A tune is not 100% mandatory with headers/cats but you could run in to throwing codes which is a pia
There might be very minimal gains with aftermarket cat backs, surely a weight savings and sound maybe a few hp on the dyno but no seat of the pants feel
Old 07-30-2012, 08:44 AM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
If you swap the headers you would at least want to also go with high flow cats. It would be counter productive to have headers pushing into restrictive factory cats. The rest of the factory exhaust system flows pretty well though.
Old 07-30-2012, 10:34 AM   #9
Juiced1
Drives: 2012 2SS CAMARO 45th
A real nice set up is the ARH long system if you plan on keeping your stock mufflers. This will replace everything all the way back to the muffler and will offer great power gains and sound. With the stock mufflers still in place it'll stay pretty mild compared to other set ups with headers. If you ever decide you need it loud a cut out works great with that set up.
Juiced1 is offline   Reply With Quote
Old 07-30-2012, 12:58 PM   #10
Bo White
Bo White's Avatar
Im going to do LTs with the stock midpipe and axleback this winter. Before and after on the dyno will be posted.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 07-30-2012, 01:26 PM   #11
gb2ss
Drives: 2011 IBM 2ss/rs m6
I did ARH LT last week and LOVE IT! Already had cat-back,LT made an impressive gain in performance and sound. Have not tuned yet, but no CEL so far. Definitely recommend these LT and hi-flow cats.
gb2ss is offline   Reply With Quote
Old 07-30-2012, 02:41 PM   #12
TSSUNAMI
TSSUNAMI's Avatar
Or you could do LT's HF Cats, stock H Pipe and a muffler delete if you want to scare children like I do right now with my car.
LOL I'm probably doing an axleback or a resonated H pipe to tame the sound a little.
Old 07-30-2012, 04:47 PM   #13
longbeachss2010
longbeachss2010's Avatar
Drives: black SS
What do you have .. I have kooks lt high flow cats no muffles .. scared the shit of my neighbours 6 am nd kids
longbeachss2010 is offline   Reply With Quote
Old 07-30-2012, 11:39 PM   #14
DonutSS
DonutSS's Avatar
Drives: '12 ZL1 SIM ADM Built
I installed Kooks LT's with hiflow cats and kept stock mid pipe and axelback. much louder than stock above 3k rpms and especially above 4k.. I didn't do a dyno run but prob gained around 30hp with tune, the extra power is noticable escpecially when you add a CAI and have it tuned. It's an incredible mod and worth the time and $$
DonutSS is offline   Reply With Quote
