Old 08-05-2012, 12:52 PM   #1
Zee-Ell-One
YOOZ GOTA B FREKN KIDN ME
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
Back Pop on Rev Down? Tuner Men Advice Needed.
Have always been irritated by back pop on rev down. I've seen some people on this forum actually like it! Can anyone explain what causes back pop/firing (ZL1 seems prone to it) and what can be done to minimize or eliminate it. Thanx.
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT
2013 ZL1 Camaro 6MT
2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab
2012 Aprilia RSV4 R
2015 Husqvarna FC450 Motomadness
First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter
Zee-Ell-One is offline   Reply With Quote
Old 08-05-2012, 12:57 PM   #2
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Pressure difference in the exhaust.
jimmy5 is offline   Reply With Quote
Old 08-05-2012, 01:41 PM   #3
kbar4782
kbar4782's Avatar
Drives: 2012 ZL1, 00016
Did you pull the fuse for the exhaust? Mine didn't do it until I pulled the fuse and I have 1450 miles on mine now and it seems to have lessened. Or I'm just getting used to it.
kbar4782 is offline   Reply With Quote
Old 08-05-2012, 01:48 PM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
All the V8's do it when slowing down, due to fuel cutoff programed into the ECM. It can be tuned out at the cost of losing your warranty.
Old 08-05-2012, 02:00 PM   #5
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
So if I have my car tuned and my EPS or my alternator,or my ac comp.
goes out and it has nothing to do with the tune it won't get repaired
under warranty. possibly it would only be repairs that could be
linked to the tune, if they could prove it. their is a law that prohibits
manufactures from voiding warranty's unless it says specifically in the
warranty that said changes will void the warranty. And it has
to specify exactly what changes will void the warranty.
I just read this a couple days ago I'll see if I can find it again.
www.wikipedia.org Magnuson Moss Act.
www.dummies.com Keeping your Mod's warranty in tact for dummies. Must read, explains act in the auto industry clearly.
CAM....ZL1 is offline   Reply With Quote
Old 08-05-2012, 04:38 PM   #6
2012ZL1
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Its there to protect the cats. It would void the warranty on the cats because they could be damaged by overheating without the fuel cooling.
I am going to get rid of it when I take off the cats soon.
Also..YOU NEVER LOSE ALL YOUR WARRANTY. Some people on here assume all your warranty is out the window with mods. This could not be further from the truth. There are laws designed to protect individual consumers from such practices. In order to be denied warranty legally it must be proven that the changes you made had a direct cause on the fault in question.
So if you tune out the cat protection..cats and anything beyond cats in exhaust would no longer be covered under warranty at the discretion of the dealership of course, because that can be proven to have a direct cause to an effect.
2012ZL1 is offline   Reply With Quote
Old 08-05-2012, 07:23 PM   #7
Russell James
Russell James's Avatar
It's for fuel economy. There is a table in the calibration for decel fuel cutoff. Since no power/fuel is really needed for decel, they cut it almost completely off on decel. There is then not enough fuel for combustion in the chamber, and the last little bit goes out into the exhaust and pops when it hits oxygen.
You can turn that decel fuel cutoff off in the tuning, and have no pops and no problem with the cats. Just normal combustion on decel like cars did for 100 years. Harley's do the exact same thing. If someone on a newer injected Harley puts on free flowing pipes and leaves the tuning stock, they pop like crazy. Same thing on those, you just go into the decel table and richen the fuel up until no more pops on decel.
Cat protection is part of the tuning that if the throttle is held wide open for a long time, like a 5 mile highway blast at 180... if the computer senses certain conditions it will super richen up the WOT fueling. So if you're ever blasting down the highway rediculously fast, or maybe on a dyno, and the exhaust starts pumping out dark smoke... it just went into cat protection mode.
Old 08-05-2012, 07:38 PM   #8
9secs
Drives: some
Heres the other view. They can void almost anything they want after you put a mod on. Install a tuner and the motor blows? guess what they blame it on. transmissions messing up? yep its the tuner. They can choose or not choose to honor your waranty over just about any mod but most dealerships are not that bad. I tend to take my cars to the more performance oriented dealers with higher end cars and they will overlook almost anything. And if you think those "laws" can protect you, goodluck hireing a lawyer and trying to fight GM in court over a warranty claim when the court costs will be 20x the repair.
9secs is offline   Reply With Quote
Old 08-05-2012, 07:43 PM   #9
Higgs Boson
Perpetual Order
Drives: indeed
it's not the dfco itself, it's the low timing that ramps in and out the dfco mode. the zr1 has way more, like 35 degrees to ramp it rather than like 3 in the camaro. you can just mimic the zr1 dfco spark tables and the decel burble goes away. magic, eh?
Higgs Boson is offline   Reply With Quote
Old 08-05-2012, 10:12 PM   #10
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I'm with Higgs. I have truned the DFCO off and still had decel poping on LS3 motors. Increasing entry and exit timing lessens the pop. The automatics don't seen to have any noticeable pop.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 08-05-2012, 10:14 PM   #11
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
If your exhaust has a leak it can cause popping on decel!
sammyv is offline   Reply With Quote
Old 08-05-2012, 10:41 PM   #12
SlingShot
SlingShot's Avatar
Not all your statements are true. The ECM tune can and will void your drive train warranty. They don't have to prove anything other than the ECM has been reprogrammed. You warranty is a service contract between you and the manufacture, and if YOU break any terms of that contract the warranty can and will be void. The act everyone talks about, is there to protect consumers from manufacturers changing the terms of the contract after purchase. Also the use of aftermarket parts only applies to OEM spec parts use for repair replacements.
Old 08-06-2012, 03:01 AM   #13
2012ZL1
CaRaHoLiC
I respectfully disagree. It has to be proven that what you did caused the problem.
Old 08-06-2012, 03:02 AM   #14
Zee-Ell-One
So how do you access the fuel tables to make the adjustment? Laptop program and experience or pay a tuner man? Thanx, I really want to have it sound perfect.
2013 ZL1 Camaro 6MT
2012 Aprilia RSV4 R
