![]() Drives: 2013 zl1 a6 Join Date: Aug 2012
Converter swap
Does anyone know if the factory zr1 and cts-v torque converter will fit the camaro ss 5th gen
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Have to ask why?
It is the same and will not benefit you at all as far as performance.....what are you looking to do? |
Im looking to supercharge and I already have it but I wanna get a new converter along with some other things first. And I figure the stall off of the zr1 has to be prettyl close to what I need since we will have almost the same hp and set up
BumP
The stall is the same. It is the same 6L80E trans and converter.
If you want to optimize acceleration then you would need to go with a (roots type top mount SC) 2800 stall triple disc to hold the power. A top mount SC makes torque down low so a higher stall than 2800 would bring you past the sweet spot for utilizing that tq. If you were NA, then a 3600. |
#6 |
Preciate it
