Old 05-25-2009, 11:29 PM   #1
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro ss
will adding after market headers void warranty?
lakersftbl69 is offline   Reply With Quote
Old 05-25-2009, 11:32 PM   #2
mfr1950
mfr1950's Avatar
Drives: 2011 challengerR/T , 2010 Ram R/T
I think you should ask the dealer before buying and installing a set...
mfr1950 is offline   Reply With Quote
Old 05-25-2009, 11:45 PM   #3
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
2SSJIM is offline   Reply With Quote
Old 05-25-2009, 11:49 PM   #4
lakersftbl69
ok sounds good thanks
Old 05-25-2009, 11:52 PM   #5
SummoneR
Paul
SummoneR's Avatar
Depends. If where your from is like California, the dealer has to prove that what you did to the car caused the malfunction. i.e. if you put headers on the car and the calipers bust in half... I doubt thats because you added headers. But if you added headers and say you did not reroute a cable or something like that properly and you fried something, etc... good luck trying to convince them it was not your fault for installing the headers.
Old 05-26-2009, 12:01 AM   #6
Vash
Drives: 00 Blazer
The exhaust portion yes for sure it's gone. Any problem with your cats and muffer, egr are on you after that.
Old 05-26-2009, 12:04 AM   #7
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
YES!
Old 05-26-2009, 12:35 AM   #8
BlownChevy
Drives: 2015 1SS RS 1LE
The answer is simple....Yes.
BlownChevy is offline   Reply With Quote
Old 05-26-2009, 02:07 AM   #9
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
It voids the exhaust warranty.
Will the V6 have DBW or a good old fashioned cable throttle? theholycow Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 41 08-02-2009 09:25 PM
GM Warranty During Restructuring CamaroScotty Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 27 03-24-2009 09:07 PM
Warranty Disclosure of Non-GM Products odie23 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 0 10-10-2008 09:40 AM
Lifetime Powertrain Waranty....from Chrysler?!!? Mr. Wyndham General Automotive + Other Cars Discussion 22 08-16-2007 05:16 PM
GM Adds Used-Car Powertrain Warranty KILLER74Z28 General Automotive + Other Cars Discussion 3 02-06-2007 08:56 AM
