Old 08-10-2012, 09:52 AM   #1
anglwngss
Texas Camaros
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
Driver's door won't lock
You know how if you're sitting inside the car with your keys and try to lock the doors, it'll lock, then immediately unlock the driver door?
Well.. mine is doing that except I'm not inside the car. I'm not even close to the car. It's just started it this past week. There are no other keys in the car, so I don't know why it's doing this.
It doesn't do it after every time I drive it, but definitely after every drive to work each morning. I have discovered that if I put the key back into the ignition and turn it on, then off, the car will lock and stay locked. or, if I'm out of the car for a few minutes, then drive somewhere else, it'll stay locked..
Nothing new has happened at work. We're a real low tech mom & pop place, so no new electrical devices here..
Any ideas guys?
anglwngss is offline   Reply With Quote
Old 08-10-2012, 09:57 AM   #2
wocampb
wocampb's Avatar
Drives: '14 2SS/RS 1LE BRM, '12 Cruze LT 6M
Window not up all the way?
wocampb is offline   Reply With Quote
Old 08-10-2012, 10:02 AM   #3
anglwngss
Texas Camaros
anglwngss's Avatar
Widows are up all the way, but even in the past, if the windows are rolled down, that still 'shouldn't' be an issue.
If you're asking if the windows are indexing correctly, yes, they are.
Old 08-10-2012, 10:28 AM   #4
lightner75
LoneStar Camaro
lightner75's Avatar
Drives: 2010 cyber gray 2ss
Is it still under warranty ? If so i would take it to the dealer ..
lightner75 is offline   Reply With Quote
Old 08-10-2012, 10:31 AM   #5
anglwngss
Texas Camaros
anglwngss's Avatar
If no one has any suggestions, I will eventually take it there, but I'm hoping someone has a fix or something.
Old 08-10-2012, 10:31 AM   #6
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
Sounds like the little switch in the ignition lock cylinder might be hanging up, causing the system to sense a key when one isn't present.
If it happens often enough, a tech with a scan tool could isolate that issue in short order.
Bye bye, Bumblebee!
Old 08-10-2012, 10:37 AM   #7
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
Your possessed.. call these guys
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 08-10-2012, 11:17 AM   #8
anglwngss
Texas Camaros
anglwngss's Avatar
Lol, Sounds about right!
Old 08-13-2012, 08:32 AM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
Were you able to get the issue resolved? Please let us know so we can see if there are any available options to you!
Brandon
Chevrolet Customer Service
Old 08-31-2012, 10:03 PM   #10
anglwngss
Texas Camaros
anglwngss's Avatar
Ended up disconnecting the battery cable for several minutes. Seems to have reset this back to working. o_O
whatever works is great!
Old 11-04-2012, 07:24 PM   #11
Lydon
Lydon's Avatar
Drives: 2010 2SS Camaro
I am having the same issue. It seems to be happening when I use the trunk open button on the driver's door, which poses a problem, b/c I am out at a store and the damn door won't stay locked. I end up leaving he store, going home, and the door locks fine once I get there. Any suggestions on a reset? I tried using my spare key fob thinking it might be the fob, but it's doing it with that one too.
Karen
Lydon is offline   Reply With Quote
Old 11-04-2012, 07:25 PM   #12
Lydon
Lydon's Avatar
HELP!
Brandon
I am having this issue too. Could you help me, Brandon? (And I'd rather not disconnect the battery and re-connect it just to get it to stop.)
Karen
Old 11-06-2012, 08:49 AM   #13
Drives: GM Vehicles
Have you had this checked out at the dealership? This would be the first step that you would want to take.
Brandon
Old 11-08-2012, 04:52 PM   #14
Lydon
Lydon's Avatar
Thanks.
Brandon
No, have not contacted dealer yet. I just started having the issue, and thought maybe I could find a 'fix' here on Camaro5.com
Karen
