![]() Drives: Summit White 2012 1LT/RS Join Date: Dec 2010
When is the best time to check the oil
i recently did a oil change and was curious when is the best time to check the oil level...immediatly, or wait 5 min for all the oil to settle...or wait even longer....
#2 | |
then wait about 3-5 mins and check.. make sure you're on level ground |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Warm engine, make sure you wait about 10 minutes after shutdown for the oil to drain back into the pan.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
I like to check mine after an overnight set, before the first start of the day. Cleaner reading on the stick, and all of the oil is in the pan.
Bye bye, Bumblebee!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
According to some people around here...........after it blows up.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
#7 |
it's hers...
Drives: 2011 Camaro 2SS/RS Convertible Join Date: Jun 2012
#8 |
My Dream Car
Drives: 2011 SIM LS3 1SS Join Date: Jul 2009
10 mins may not be enough time, sometimes I have had wait over 20 minutes for a proper oil level check. The LLT motors on the v6 have been known to get low or be overfilled bc we are reading it to soon, was guilty of it myself 2x and had to drain some oil out as I thought I was low
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
#9 |
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
I always check mine at a complete stop!
#10 | |
~COTW 6/30/14~
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS BUILD TIMING CHAIN FAILURE TRANSITION FROM STOCK TO CAM VID |
#11 |
Yeah, I try to do this as well
#12 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Simple, do it in the same location and same time period after shut down if you are really that worried about it. The hashmarks on the dipstick are engineered the way they are for a reason, that is the safe zone for oil level. The car, computer and gauges will not know or care if you are lower on the hashmarks than towards the top of the hashmarks.
#13 |
![]() ![]() Drives: 2010 Camaro IOM 1SS M6 Join Date: Aug 2010
