Old 08-11-2012, 02:13 AM   #1
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Looking for info Heads/Cam
I'm about to toss in my new headers and know i need a tune, but I cant see wasting a couple of hundred for a tune just to get it tuned after I install heads and a cam.
What heads and cam are people recommending for a future Whipple 2.9L SC...?
LS3
Thanks,
M
Medi0cr3 is offline   Reply With Quote
Old 08-11-2012, 04:13 AM   #2
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Studying this myself and don't know enough to answer.
FYI: You don't need to tune right away, if I were you I'd wait a month or two til you know exactly what cam/heads to get.
Also I recently read that a cam and lt headers lowers boost in a super charger, something to consider.
K32 Camaro is offline   Reply With Quote
Old 08-11-2012, 10:49 PM   #3
Medi0cr3
Medi0cr3's Avatar
Drives: 2011 2SS
bump
Old 08-11-2012, 10:54 PM   #4
Supercharged SS
Drives: 2010 Camaro
If you buy all your parts from Jannetty Racing than your tune is free. So every upgrade or change you make will cost you ZERO to have it retuned.
Old 08-11-2012, 10:55 PM   #5
Supercharged SS
Drives: 2010 Camaro
LS3
Thanks,
M
Stock heads are good up to 1000 HP or 800 rwhp. Put that money into something else. I still run the stock L99 heads.
Old 08-12-2012, 12:21 AM   #6
Sepulvadoss
Drives: 2013 zl1 a6
Correct me of I'm wrong but lts are only bad for turbos. And they make boost cams
Sepulvadoss is offline   Reply With Quote
Old 08-12-2012, 07:05 AM   #7
Higgs Boson
Perpetual Order
Drives: indeed
Long tubes will only work with rear mounted turbos, front mounts will take, usually, a custom shorty or manifold supplied with the kit.
There are certain cam grinds that favor boosted applications. Some favor high rpm applications, some are better for street, nitrous, road racing, etc. You pick your cam based on intended use. I have a cam in my drag car that is so big it won't idle under 1500, but the motor spins to 9K.
Higgs Boson is offline   Reply With Quote
Old 08-12-2012, 07:59 AM   #8
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Mast Motorsports black label are the best heads bar none for the 5th gen..JRE, LPE, etc all make great boost cams, pick one.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 08-12-2012, 10:01 AM   #9
Higgs Boson
Perpetual Order
Drives: indeed
mast heads are works of art that belong on display. I'm not sure I'd get those dirty.
Old 08-12-2012, 11:14 AM   #10
tvwilkes
tvwilkes's Avatar
Drives: 2010 Camaro 2SS
Call TSP and look into the PRC line of heads. You can have the factory LS3 heads ported or buy a complete aftermarket set.
tvwilkes is offline   Reply With Quote
Old 08-12-2012, 12:23 PM   #11
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Yeah stock heads are good up to those large power levels but that doesn't mean they don't make power. Come on SuperchargedSS, you know if you had put a ported or aftermarket set on that you would be making AT LEAST 20RWHP more than you are right now. It might have been the difference between a 10.0 consistant car and a 9.9 consistent car. Seriously though if your a L99 a ported or aftermarket set is a good investment when doing a cam because the heads have to come off anyway. If your a LS3 I would say its not worth it until you build the motor or have the heads off for some reason.
