Old 08-11-2012, 03:51 PM   #1
JT3640
JT3640's Avatar
Drives: 2012 ZL1, 2012 QX56
Yellowish Spots on Summit White Paint
I have a 2012 Summit White ZL1
I clean the car every time after I drive it so I know every square inch of the car.
I've been noticing yellowish spots on the sides of the car that appear to be coming up under the clear coat that cannot be buffed out.
Has anyone else been seeing this.
I will be taking it to my dealer next week to see what is going on with the paint.
This is a bit concerning I don't have a clue where this coming from and it's getting worse by the week.
Anyone else with this issue?
JT3640 is offline   Reply With Quote
Old 08-11-2012, 04:15 PM   #2
srt0739
Drives: 2012 Camaro ZL1
Maybe from the tire shine/dressing?
srt0739 is offline   Reply With Quote
Old 08-11-2012, 04:29 PM   #3
JT3640
JT3640's Avatar
If so i would think it would buff out wouldn't it?
That would me the paint is a little bit delicate which is unacceptable to me and I'm sure everyone else.
It looks like its under the clear coat which I know seems a bit more than weird but I'm not a paint guy either.
Old 08-11-2012, 04:40 PM   #4
srt0739
I know I've seen some forms where people had some stains from the tire dressings and the spots have faded over time. Guess some tire dressings have strong chemicals that penetrate clear coat.
Old 08-11-2012, 05:02 PM   #5
JT3640
JT3640's Avatar
Thumbs down
Thanks
For sure I won't be using the ones I have now for sure.
Old 08-11-2012, 05:03 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Hit the detailing forum...Adam crew was fixing someone summit white with this kind of thing at fest.
-John S.
Old 08-11-2012, 05:06 PM   #7
JT3640
JT3640's Avatar
How do I find it?
Old 08-11-2012, 08:39 PM   #8
Zee-Ell-One
YOOZ GOTA B FREKN KIDN ME
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
Originally Posted by JT3640 View Post
How do I find it?
Im not going to over dress my tires or clear bra or wax untill the paint is completely cured for a couple of months.
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT
2013 ZL1 Camaro 6MT
2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab
2012 Aprilia RSV4 R
2015 Husqvarna FC450 Motomadness
First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter
Zee-Ell-One is offline   Reply With Quote
Old 08-12-2012, 09:11 AM   #9
JT3640
JT3640's Avatar
You could be right with the tire dressing the first two spots that appeared were not on the car when I picked it up and the dealer did dress the tires.
My car was built on may 31st as far as the paint curing these spots just showed up last week when I dressed the tires for the first time in a month.
All I know is the spots will not come off the paint with anything that I am currently trying.
I sure hope that I can find something to remove the spots.
Any help would be greatly appreciated.....
Old 08-12-2012, 09:22 AM   #10
stlrammer
Drives: 2017 1SS Blue
Unless it's really bad don't let your dealer talk you into repainting it.
stlrammer is offline   Reply With Quote
Old 08-12-2012, 02:01 PM   #11
JT3640
JT3640's Avatar
Well I've tried just about everything four different high end waxes and nope nothing worked. I will have to get it checked over by a good detailing shop I'm sure they have run in to it before. It's amazing how sensitive the paint is and I guess if its the tire detail compound well they shouldn't be selling it as far as I'm concerned.
Old 08-12-2012, 03:59 PM   #12
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
It's probably Rail Dust
gml1998 is offline   Reply With Quote
Old 08-12-2012, 04:38 PM   #13
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
I have something similar happen to my back quarter panels! I'll post some pics and tell me of it kinda looks the same. Mine are a golden oil color almost black! Have you tired bug and tar remover?? That kinda "lightened" mine up! I was also told to use a clay bar to see if that helped! I haven't been able to do that yet, as I'm not too comfortable with using clay bars! Mine I believe was from the tire dressing the dealership used! I also drove mine the 1,500+ miles home too!!
Order # QHQWJF
Current Status: 4200 VIN 142
1100, (04/25/12): 2000, (05/21/12): 2500, (5/22/12): 3000, (5/22/12): 3100, (5/31/12): 3300, (5/31/12): 3400, (6/7/2012): 3800, (6/15/2012): 4000, (6/15/2012): 4104, (6/15/2012): 4106, (6/19/2012): 4150, (6/19/2012), 4200, (7/16/2012), 4300, (7/18/2012), 4B00, (6/15/2012) , 5000, (7/25/2012)
6000, Delivered to the customer (8/2/2012)
b_williams_82 is offline   Reply With Quote
Old 08-12-2012, 05:01 PM   #14
b_williams_82
Let me know what you guys think of this!! You can faintly feel the spots, which leads me to believe that I should be able to get it with a clay bar. Any thoughts?? Also, does this look like the problem you're having?
Order # QHQWJF
