Old 08-12-2012, 03:43 PM   #1
MyOrangeSS
MyOrangeSS's Avatar
Drives: 2010 Camaro 2SS
Arrow valve springs???????
About a year ago I put in the Livernois stage 2 Max cam with a .603 intake lift and a .618 exhaust lift 114 LSA. Livernois recommended dual valve springs and had a kit but they were very $$$ so I called COMP to see if they sold a set cheaper and what they recommended. I ended up getting a set of Beehive PN 26918-16 which has a max lift of .650". I have put about 8,000 miles on the car as well as supercharged it since then. It runs great, but at what point do I need to put a new set of valve springs in? The car only has 11,500 miles on it now and I do drive it pretty hard at times. I dont want to break a spring and drop a valve ( which I have literally had nightmares about ) and am looking for advice as well as if any one knows of a good kit
MyOrangeSS is offline   Reply With Quote
Old 08-12-2012, 04:01 PM   #2
Bo White
Bo White's Avatar
Im assuming you did not replace the retainers with Ti ones. The beehives do fine up to about were your at. What I would do is pull them off and check the pressures and if they are still good put Ti retainers on when you reinstall the 918s. If they dont check out then I would put some dual springs on.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 08-12-2012, 04:31 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Correct me of I'm wrong but aren't 918's good for .600 lift?
I would go with a dual spring for piece of mind and better "reliability" because you never know in this hobby but dual spring have saved my azz once.
Comps 925 is a good one too IMHO.
Old 08-12-2012, 05:54 PM   #4
MyOrangeSS
MyOrangeSS's Avatar
corrected
the max lift on the 26918 is .625"
heres another thing I was told, and can anyone tell me if this is true or false........ If I go dual springs I will need to upgrade my timing chain, COMP told me that....... they were also the ones that told me that I didnt need dual's, so far there right!?!?
Old 08-12-2012, 06:03 PM   #5
Bo White
Bo White's Avatar
The Brazilian race series simular to the Australian Super Car uses 918s in thier 416" engines with 24x/25x-.61x/.63x cams for what I understand for a full season but with Ti retainers.
Totalled:
Old 08-12-2012, 06:07 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
its not that duals are necessary, its that they add extra reliability. personally i have broken a spring and was able to drive on the extra spring. i would never run single springs.
Old 08-12-2012, 06:21 PM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
^^This. If you ever break a spring on those beehives that you have then there goes the motor becuase the valve will drop causing all kinds of carnage. Just think if it happened in the middle of a WOT run? Yikes
Old 08-12-2012, 06:27 PM   #8
Bo White
Bo White's Avatar
Agreed on the added insurance. Race teams can afford to throw another engine in but on the flip side of the coin they dont want to pull out of a race because of a valve spring issue.
Totalled:
Old 08-12-2012, 06:51 PM   #9
js19racer
js19racer
js19racer's Avatar
Drives: 2011 Camaro 2SS/RS
Check seat pressure, thats the only way to tell if they need to be replaced. Titanium retainers are only to lighten the valve train.
js19racer is offline   Reply With Quote
Old 08-12-2012, 06:57 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I don't know about .625 fellas here's what I found to name a few.
http://www.texas-speed.com/p-1379-co...shrod-kit.aspx
http://www.hinsonsupercars.com/p-966...rings-600.aspx
But comp says...
http://www.compperformancegroupstore...Category_Code=
It's too close to call but like stated. Duals saved my azz too.
Old 08-12-2012, 07:16 PM   #11
JEFF75645
Drives: his wife crazy buying mods
I'm going with Patriot .660 dual springs for added insurance myself.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 08-12-2012, 07:23 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Remember your don't want a .700 lift spring on a .625 lift cam. You want the spring to come close to coilbind do it can performe to its full potential. So if you get a .625 cam a .650 spring would be good but that's where a properly installed spring and measuring good comes in some even need a Lil shimming and you'll be set. Also it's the middle of August and of your a seasonal owner like me don't forget to loosen up your rockers and relieve the pressure on the springs when you put your car away.
Old 08-12-2012, 09:15 PM   #13
Bo White
Bo White's Avatar
Thats what I say too.
Making the valvetrain lighter will help the springs maintain stability.
Totalled:
Old 08-12-2012, 10:03 PM   #14
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2013 Camaro ZL1 M6
What kind of springs do you have? Was it rated for your cam and how did you know you had a problem and to check the springs. Thanks
1Camaro2SS is offline   Reply With Quote
camshaft, valve spring, valve train
