![]() Drives: 2010 Camaro 2SS/RS IBM 6spd Join Date: Jan 2011
How fast can we safely come to a stop?
Im gonna go to an event where there is 5000ft of runway and a police officer there to radar your top speed. Im wondering how long I can get on it and safely come to a stop at the other end. Cautiously I was thinking after a half mile, roughly 2500ft, would be time to start slowing down. A quarter mile would be plenty to slow down though wouldnt it? Any thoughts?
![]() Drives: 2012 2LT 45TH Anniv. RS Package. Join Date: Oct 2011
IT'S A TRAP!!
Jk. No but you should turn your wheel the entire way and slam on the brakes while pulling up the emergency brake. |
![]() Drives: 2011 ss silver black strips 6 speed Join Date: May 2012
I may be wrong but I thought 60 to 0 was like a hundred and fifty feat,and thanks to everyone I love this place
Emerald Coast Camaros
Drives: 2010 2SS/RS Camaro IOM/IO Join Date: Aug 2009
Is this some type of free for all event, or will there be markers? I would think that the radar gun would be positioned at set spot, and you can start braking from there. I went to a 1/2 mile event a while back, and there was a sign at the 1/2 mile mark that said "brake now." And I mean to say....you had better brake!!!!
ECC on Facebook
2010 Camaro SS/RS IOM, IO interior, Custom Striping, Razzi body kit ADM CAI w/scoop/Dynatech Headers & Hi-Flow Cats/Solo Performance Exhaust, FTI 3600 Stall/Comp Cams custom grind cam/LS3 conversion/FAST 102 Intake |
Amanda
I know I went from 60-0 pretty damn fast with a car length away in traffic last week.
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
#7 |
The magic smoke genie....
Drives: Jewels (2010 RJT 1SS) Join Date: Dec 2009
This will most likely be an organized event. The organizers will have setup braking zones that will be more then long enough to stop. most likely it will be long enough to land a 747 on. lol.
And, unless you've tuned/modified your car, I'm predicting you'll hit 155, give or take 5mph for calibration/metering errors. |
#8 | |
![]() Drives: '87 T/A, '87 IROC, '70 Grand Prix Join Date: Oct 2011
Stopping in a straight line using your brakes (not the e-brake) will be the quickest and safest way to stop. |
#9 | |
I am reasonably modified and was one of the fastest Camaros in attendance that day -- at 145. Not trying to be a downer because I know you're going to have fun. Just don't want your expectations to be too high. Of course -- you could be racing under completely different conditions....so good luck!!!!
ECC on Facebook
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
Even if the event is not organized to the extent that there are braking markers, most runways are marked with distance remaining in 1000's of feet. Take a look the next time you have a window seat on a flight. You'll see a 5, then a 4, etc., on a sign by itself. The signs are there to tell a pilot whether or not he has enough room to abort a takeoff or if he's going to have to go airborne and do a go-around.
1K feet should be sufficient for any speed a limited Camaro can achieve. John B.
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
#11 |
#12 | |
#13 |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
n201mw, I've attended the "Texas Mile" Event. the traps are set at the Mile Marker, the track (Runway) was 8000 foot....so there was roughly 3000 foot to stop, and there were cars/bikes clocked at well over 200 mph, the record was set at 257 mph. If your event is a half mile track.....you will have MORE that enough time to stop with your car.
#14 |
Drives: 2011 2SS Join Date: Sep 2011
I'd count on 1000 feet to be safe.
According to MotorTrend, the 5th gen SS takes ~300 feet to stop from 100 MPH. That doesn't take into account a reaction time. At 100 MPH you're traveling at 147 feet per second for a total stopping distance of ~447 feet. This calculator (assuming a 0.75 coefficient of friction) gives 446 feet for 100 MPH which jives with the MotorTrend test. At 150 MPH, the calculated distance is 1004 feet. |
