Old 05-27-2009, 01:28 AM   #1
CamaroDan
CamaroDan's Avatar
Drives: 2007 dodge charger
What other engines can you put in SS?
What other engines can you order and put in the ss?
CamaroDan is offline   Reply With Quote
Old 05-27-2009, 01:37 AM   #2
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
If you got the money, you can get just about any crate engine you want but not from the factory. You would have to get the car and the engine and put them together.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-27-2009, 01:38 AM   #3
blackedout010
Drives: on order black 2010 2ss
ls7 or any lsx motor
blackedout010 is offline   Reply With Quote
Old 05-27-2009, 01:44 AM   #4
CamaroDan
CamaroDan's Avatar
I can order it that way or do you have buy the engine first and have them put it in?
Old 05-27-2009, 01:46 AM   #5
blackedout010
no you can only order the 6cyl, l99, or ls3 with the car
Old 05-27-2009, 02:01 AM   #6
CamaroDan
CamaroDan's Avatar
Damn That sucks was hoping to get the zo6 engine and mod it from there.:(
Old 05-27-2009, 02:08 AM   #7
CWI
CWI's Avatar
You can buy a LS7 crate engine and replace the LS3 or just build the LS3 would be a LOT more economical and get the same power
Old 05-27-2009, 02:11 AM   #8
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
+1
for the money you'd spend on an LS7, you could well surpass the power output with a built LS3. just look at the (dare i say it) hennessey car - 8 grand for a blower, intake, & tune and he's already over 550hp.
to the OP, you can put anything you want in it... it just depends on how much work, time, & money you're willing to invest. any of the newer LS engines will be the easiest & best options to go with.
Old 05-27-2009, 08:47 AM   #9
nards444
nards444's Avatar
Drives: 1SS/RS Black
the ZO6 motor should fit because isnt it just the LS3 with twin turbos on it. You would have to make sure there is hood clearance. But you can only get the factory options that others have said. Before you buy a crate motor make sure you talk to somebody that knows what they are doing and make sure the engine would fit. Instead of buying a new motor I would get a charger or turbos put on that. A charger would run you about 4 or 5 and would be cheaper than a new motor with install, and a charger should give you mid 500's to 600hp, which is as much as the vette. Twin turbos would run you 8.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 05-27-2009, 08:54 AM   #10
zebra
zebra's Avatar
WOW!!
sorry, but half of that's just flat wrong!
the Z06 uses a naturally aspirated engine, the LS7
it's a 427ci (7.0L) engine, but it is still a GenIV LS block, meaning it shares the same external dimensions as its siblings like the LS2, LS3, etc. there is no clearance issue, as seen on the LS7 Camaro from SEMA
turbos also typically don't interfere with hood clearance - that would mainly be a supercharger issue, which has been shown a few times to not be a problem either.
this particular S/C kit puts you around 550hp for about $8k installed... that's about what you'd pay for a twin turbo kit, but i'd expect a little more power from the turbos.
you do have a good point in mentioning that you should check for clearance issues before buying an engine, but unless you're going with a big block or some crazy blower scoop, i doubt it'll be an issue.
Old 05-27-2009, 08:56 AM   #11
stratman
Goldmember
stratman's Avatar
Drives: 06 CTS-V
Seriously?
The ZO6 is all motor friend. If you have the money you can fit any motor in the car you want.
stratman is offline   Reply With Quote
Old 05-27-2009, 08:58 AM   #12
stratman
Goldmember
stratman's Avatar
Drives: 06 CTS-V
Beat me Zebra. And with illustrations. LOL
Old 05-27-2009, 09:01 AM   #13
nards444
nards444's Avatar
sorry thought the LS7 had twin turbos or it was available. but all in all the LS7 is SIMILAR not exact to the LS3. The key is if you have the money to make it fit, think he would be better off with a charger or turbos on the LS3 a lot les mods.
Old 05-27-2009, 09:03 AM   #14
stratman
Goldmember
stratman's Avatar
Drives: 06 CTS-V
Why do you think it won't fit exactly?
What does "SS" stand for? LDGn63 5th Gen Camaro SS LS LT General Discussions 208 01-11-2010 10:00 PM
GM cars could get BMW engines Tran General Automotive + Other Cars Discussion 36 11-12-2009 11:00 AM
I think Chevy just lost me on the SS... V6 for me. Supercoolyo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 10-23-2008 08:38 PM
rs ss??? CaptianSam Camaro Photos | Spyshots | Video | Media Gallery 17 10-15-2008 04:17 AM
Gas engines: Here to stay Mr. Wyndham General Automotive + Other Cars Discussion 0 05-05-2008 04:34 PM
