Old 08-16-2012, 06:44 PM   #1
ShowSStopper
Drives: 2012 Camaro 1SS Black Coupe
Exclamation Heads Up For K&N Intake Users
Just thought I would let everyone know that GM has issued a bulletin about K&N cai's causing a failure in cylinder #7 on Camaro SS models. In the event you are using a K&N intake and experience a failure, GM WILL NOT COVER THE FAILURE UNDER WARRANTY. This bulletin was specifically for the K&N brand CAI systems and was specifically for the V8 model Camaros across all Gen 5 production years.
I just wanted to give everyone a heads up on this as I found out about it today at the dealership. I'm guessing if you swap the stock setup back in before taking it in, you might be alright.
Anyway, thought i would share.
ShowSStopper is offline   Reply With Quote
Old 08-16-2012, 06:52 PM   #2
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I have a V6 and a K & N 63 series and have never had any cylinder firing issues.
=Stephens= is offline   Reply With Quote
Old 08-16-2012, 06:57 PM   #3
SuperSport2011
SuperSport2011's Avatar
Drives: 2011 camaro 2ss/rs rally yellow L99
SuperSport2011 is offline   Reply With Quote
Old 08-16-2012, 07:13 PM   #4
tjk_art
Drives: 2010
Originally Posted by SuperSport2011 View Post
tjk_art is offline   Reply With Quote
Old 08-16-2012, 07:17 PM   #5
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
That's because people aren't smart enough to clean the excess oil off the filter before they put it in or they over oil it when they clean it. The excess oil gums everything up. The SS isn't the first car to have problems with people not following the k&n instructions properly. Although this is the most severe problem I've heard about. Usually it just gums up the MAF sensor and is fixed by simple cleaning the MAF.
I was thinking about getting the k&n, and truth be told, if the parts store would have had it, I would have bought it already. I'm too impatient to order one. I may still get one anyway.
MikeSVX is offline   Reply With Quote
Old 08-16-2012, 07:18 PM   #6
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Maybe because you don't have a cylinder #7
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 08-16-2012, 07:22 PM   #7
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
This is why everything should be made WITHOUT a warning label. Survival of the fittest.
Oxtar41 is offline   Reply With Quote
Old 08-16-2012, 07:58 PM   #8
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
I thought I loved this forum before, but this thread seals the deal...
ga0358 is offline   Reply With Quote
Old 08-16-2012, 08:09 PM   #9
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Link to bulletin? I find it strange that they're blaming K&N intakes specifically. On the JRE CAI shootout the K&N Air Charger AFR was 12.0:1; very safe. If it were due to the oiled filter you would think they would be blaming almost every intake instead of just one, although I know some K&N filters are a little heavy on the oil out of the box, and it seems most end users over oil them...
Just wondering what they are claiming specifically caused this?
Jason@JacFab is offline   Reply With Quote
Old 08-16-2012, 08:10 PM   #10
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I know, that is what makes it funny. I only have 6 cylinders. Maybe I should have put a (sarcasm) quote after it. LOL
Old 08-16-2012, 08:20 PM   #11
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Kahdir is offline   Reply With Quote
Old 08-16-2012, 08:30 PM   #12
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
Just does not make sense , filter oil should not cause any piston or cylinder failure. The stock PVC hose blows oil through the intake already unless you have an oil catch can. Just can't be filter oil related.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 08-16-2012, 08:35 PM   #13
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
I bought a USED 2ss/rs and it had a K&N already installed So who's problem would that be i didn't put it ON ????? Came that way from the Dealers
Lets ASK the GM Customer Guy who comes on here all the time
skipinminn is offline   Reply With Quote
Old 08-16-2012, 08:36 PM   #14
moserbe
moserbe's Avatar
Drives: 2012 Camaro SS
I'd like the link to that bulletin also.
moserbe is offline   Reply With Quote
