Old 08-21-2012, 06:21 PM   #1
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Killer Camaro responsible for death
Of a blue jay
Must of sucked it in on the way home from picking up my son!!!
Sent from my DROID X2 using Tapatalk 2
Black CIA -Powder Coated Red Air Scoop - Vmax Ported Throttle Body - Ceramic Coated Dynatek Headers - High Flow Cats out thru factory Cat Back - JRE rough idle cam package - Trunion Upgrade - Valve Springs - Hardened Push rods - 3 bolt timing gear - SLP Under drive pully- Washer bottle relo kit - Hurst Short Throw Shifter with updated pin bushing from C5 member NH-SS - IdealG's improved Master Cylinder - GTO Clutch reservoir - L99 Brake Reservoir - Stainless Braided clutch line - wrapped up with a JRE Tune My SS layed down 462 hp on JRE's Superflow Dyno
RogerBzSS is offline   Reply With Quote
Old 08-21-2012, 06:37 PM   #2
fbodyauto
fbodyauto's Avatar
Drives: 2012 Chevrolet Camaro 2LS
Wow, now my grill has killed generations of bugs but never a bird!
fbodyauto is offline   Reply With Quote
Old 08-21-2012, 06:42 PM   #3
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
At least he matched your car.
Bye bye, Bumblebee!
Old 08-21-2012, 06:44 PM   #4
rez333
Drives: 2013 ZL1
Some cars don't even have grilles. What would have happened to the radiator in those cases?
rez333 is offline   Reply With Quote
Old 08-21-2012, 06:47 PM   #5
mcbeth15
mcbeth15's Avatar
Drives: '11 RS 2LT IBM
Possible suicide ????
mcbeth15 is offline   Reply With Quote
Old 08-21-2012, 06:53 PM   #6
orangejuice
H1 OFCR
orangejuice's Avatar
Drives: 2013 ZL1 Blue Ray Metallic
Originally Posted by rez333 View Post
Some cars Udon't even have grilles. What would have happened to the radiator in those cases?
would of destroyed the radiator coil for sure especially at highway speeds
orangejuice is offline   Reply With Quote
Old 08-21-2012, 07:23 PM   #7
cbass
Drives: .
That blue jay probably tried to mate with your blue car......looks like it didn't work out.
cbass is offline   Reply With Quote
Old 08-21-2012, 11:11 PM   #8
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Were you able to get all of it out?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 08-21-2012, 11:34 PM   #9
2012SS
2012SS's Avatar
Drives: 2012 V.R. Camaro SS, '67 Camaro
I hit a jack rabbit the other day......lol
2012 Camaro SS Victory Red, CAI intake, Flowmaster Outlaw Catbackhttp://i5.photobucket.com/albums/y186/69hotrod/5ecc4bef.jpg
2012SS is offline   Reply With Quote
Old 08-22-2012, 02:08 AM   #10
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Bluejay says "Day-umm - nice Cama..."
Tori
Old 08-22-2012, 02:18 AM   #11
Todd45thAnniversaryV6
Todd45thAnniversaryV6's Avatar
Drives: 2012 45th Anniversary Camaro
Maybe he was hoping to make a meal of the bug carcasses stuck to your bumper. Should have waited till the car was parked.
2012 45th Anniversary 2LT Bone freakin' stock......for now.
Todd45thAnniversaryV6 is offline   Reply With Quote
Old 08-22-2012, 03:44 AM   #12
Dizzy
Dizzy's Avatar
Drives: Black 2011 2ss
Dizzy is offline   Reply With Quote
Old 08-22-2012, 04:11 AM   #13
Chevrole+
Chevrole+'s Avatar
Drives: 2010 Camaro 2LT
just be happy it wasn't a pterodactyl!!! that would have been a mess!!!
I hit a bird 1 time. got sucked onto my air filter in my engine bay (vararam)
found it a few days later when checking the oil. lol
Chevrole+ is offline   Reply With Quote
Old 08-22-2012, 04:40 AM   #14
Brutal SS
Brutal SS's Avatar
Drives: 2019 Camaro 2SS 1LE
If this had happened to me, my Camaro would need to floss!
Brutal SS is offline   Reply With Quote
