08-22-2012, 09:51 AM | #1 |
Aikman Performance Tuning
underdrive pullys
i was wondering if there were any underdrive pullys out there to get more boost and increase blower whine and if so which are prefered ? and maybe a good tuner ?
08-22-2012, 11:53 AM | #2 |
Drives: 2013 Ashen Gray Metallic-M6 Join Date: Aug 2012
I've been researching this like crazy and there's a few options, smaller sc pulley which many of the sponsors on here carry and also changing out the crank pulley to overdrive the blower. It seems if you go too big on the crank to like a 10.00" you have to also change out the ac pulley and idlers. Hope this helps, Im still trying to learn all this with the zl1 as well.
08-22-2012, 12:17 PM | #3 |
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
They are not actually underdriver pulleys. In fact, they would realy be looked at as supercharger overdrive pulleys. We make a set of uppers that work with the blower and with with Innovators West on the lower setups. There are a lot of options depending on the blower speed someone wants.
08-22-2012, 12:18 PM | #4 |
thank you hopefully we can find more options out there im a heavy line performance tech at a dealer in austin tx just wanna get that beautiful blower whine as well as a few ponies. Would i need a new tune ?
08-22-2012, 12:56 PM | #5 |
I'm wanting to run about 14-15 psi, what combo do I need for this? Where does the pcm shut off and bleed excess boost? I thought I read something about that as well.
08-22-2012, 01:34 PM | #6 |
Drives: Camaro ZL1 Join Date: May 2012
If you want 15 psi, be prepared to run meth or get a new H/X setup. Your IAT2s will be through the roof on the stock setup.
08-22-2012, 01:41 PM | #7 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
TVS blowers really dont have a lot of whine to them unfortunately. I used to have an Ion Redline (same thing as the Cobalt SS) and I put a TVS on there, and I couldnt hear it at all. Produced way more boost than the stock M62, but didnt offer much in the sound department. You might hear it if you were driving against a wall, but out in the open, No. Yes, you would need a tune for increased boost. I dont know what stock boost is on a ZL1, but no matter what pulley you put on, the computer wont let boost go over its set point. Same with my Ion.
2010 Camaro SS LS3 - No Modz
08-22-2012, 01:59 PM | #8 |
Drives: 2013 ZL1 Ashen Gray / Manual Join Date: May 2012
My tuner told me the best way was to put a full pully kit(crank, blower, idler) to get the ratio wher he wants it. He is also porting the blower and snout. It's going to create alot of heat so I'm opting for the super chiller. Should keep everything cool, he said it will keep an aggressive time and should keep heat soak down. That was my main concern.
08-22-2012, 03:20 PM | #9 |
what flash programmer should i be going with
08-22-2012, 03:52 PM | #10 |
Eh, that'll happen
Hptuners or efilive will give u full access to the computer.
08-22-2012, 05:56 PM | #11 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
To get 15lb boost, you will need to swap both the crank and supercharger pulleys.
9.1 crank and 2.55 SC pulley. Aspire performance is located in Austin. That's where I purchased my gear from.
2017 ZL1
A10 Redhot with stripe |
