Old 08-23-2012, 10:21 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
3/8 iceolator + Ported Manifold
Has anyone dyno'd the hp increase with the 3/8 iceolator and ported manifold? All the dyno numbers are using a combination of the 1inch and the ported manifold. Just curious because I know the 3/8 size lends itself to more hp in the higher rpms.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 08-23-2012, 10:34 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Similiar gains, would be my guess, Not totally sure tho
Lil' Nasty is offline   Reply With Quote
Old 08-23-2012, 10:40 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
You'll probably get higher hp but less tq
Old 08-23-2012, 11:45 PM   #4
LVDran
LVDran's Avatar
Drives: 2010 V6
I'm thinking I read that the 3/8 gave more tq than HP and the 25mm vice versa. I could be backwards though.
LVDran is offline   Reply With Quote
Old 08-24-2012, 12:07 AM   #5
JohnZ
JohnZ's Avatar
I also think the 3/8 would give more hp, but I would be curious to see how much with the Ported IM.
Old 08-24-2012, 12:36 AM   #6
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Check either the vendor section under v6 bolt ons or search in this section there are dynos posted. Diff between the 3/8" and 1", both with the ported IM - the 3/8" made literally a couple hp more on the top end. the 1" made just a little more in the lower rpm. Maces Ported IM and the 1" is either 31 or 33rwhp. Going from memory but in that ballpark.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 08-24-2012, 01:22 AM   #7
lscamaro
lscamaro's Avatar
Your correct!
The mace makes more low end torque and the black ice makes more hp at the top!
Old 08-24-2012, 01:23 AM   #8
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
So witch is better for drag racing?
2010_camaro is offline   Reply With Quote
Old 08-24-2012, 01:27 AM   #9
lscamaro
lscamaro's Avatar
Really up to you. Just remember, torque wins races. Plus our car isn't really that slow once it gets going but its getting it out of the hole that is a challenge. I personally went with the mace for the added torque down low to do just that. Also, you can really feel the low end torque when driving on the streets. I really like that as well. Most have said that the rx really doesn't kick in until 4000 and since I'm usually never there while daily driving, I opted for the mace.
Old 08-24-2012, 02:10 AM   #10
2010_camaro
where did you order the MACE and how much to the door? I have been up in the air on witch to buy. Did you port match your heads? I see you already have the Ported IM
Old 08-24-2012, 12:34 PM   #11
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
if you go to the dyno sticky your will see my latest dyno. I have the 3/8 iceolator and the mace ported manifold. My prior dyno was 254 before those mods on a dynometer. I then installed the 2 pieces and got 254 on a mustang dyno which the geneneral concensus is usually reads around 15-20% lower, the dyno op even told me that, so my 254 on a mustang could really be anywhere between 292 and 304 hp, plus it was 90 degrees and high humidity the day I went
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 08-24-2012, 01:55 PM   #12
SC2150
We have both the 3/8" and 1" (1" in stock) and the diff we saw was the 1" gives 3-5 more tq down low and above 5,000 rpm it was app 14 rwhp lower than the 3/8". So get the 1" if you dont run for quickest ET at the track and the 3/8" if you do.
Old 08-25-2012, 10:03 AM   #13
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
no need to stack the spacers it doesn't work that way
