Old 08-24-2012, 09:36 AM   #1
stclair
Drives: 2012 Camaro 1LT
V-led Type2 switchback issuse
Ok so i bought some vled type2 swtichback turnsignals and installed them yesterday with 6 ohm resistors. Type 2 switch back are supposed to stay white normally then when the turn signal is applied the alternate to amber/off/amber/off ,etc. These do that until they are on for a while or the car alternator kicks in they then behave almost like type 1 bulbs. Which do a amber/quick white flash/amber when the turn signal is applied
I saw on a couple other forums that some have had this issuse with these but they have no update for over a year. My question is has anyone else on this forum experienced this and if so how did you resolve this? I do have an email out the v-led on this.
Thank Guys
stclair is offline   Reply With Quote
Old 08-24-2012, 02:08 PM   #2
H3LL1ON
H3LL1ON
H3LL1ON's Avatar
Drives: 2010 1LT Camaro Synergy Green
I have had them for a year and half now with no problems. That said it may be a grounding issue or a faulty resistor. Check {with gloves} if both resistors are equally hot to touch. If you find a cooler one swap it out.
Then obviously double check all wires and connections. Also make sure the resistors are not too close to other electrically sensitive parts. Hope this helps.
It's Green, really Green! C5
H3LL1ON is offline   Reply With Quote
3157, bulb, switchback, turn signal, vled
