Old 08-24-2012, 05:14 PM   #1
Bradrulz
Drives: 2011 Camaro 1LT IOM
Arrow Changing oil yourself -- what is everyone using?
I am thinking of starting to do my own oil changes as it is a fraction of the cost and you don't have to worry about someone not respecting your car.
Wondering what supplies/tools everyone is using on a 1LT V6?
Tire ramps?
Just a floor jack?
Oil catch?
What oil filter brand?
What oil brand?
I am thinking of using Amsoil XL, but still do the changes every 4,000 to 5,000 miles.
Thanks for any advice.
Bradrulz is offline   Reply With Quote
Old 08-24-2012, 05:30 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
No difference in what trim level (V6) oil you would use
I used a floor jack and two stands (I assume ramps would be safer)
Mobil 1 extended performance 5W-30 *Full Synthetic and filter M1C-254 (it's 20$ just to let you know)
I don't know if your 2011 is a late model or not but GM put in better timing chains because the ones before than arnt as strong and are prone to problems that being said....the timing chains LOVE Full synthetic oil. Good luck
Ps have the oil canister over to the right passenger tire because it Tends to shoots out a little far. (no perverted jokes
Lil' Nasty is offline   Reply With Quote
Old 08-24-2012, 08:26 PM   #3
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Couple of ramps 2 floor stands for added safety and basic Walmart container to drain. Then add in amsoil 100% fully synthetic with wix filter. Easy as it gets.
OOLIE is offline   Reply With Quote
Old 08-24-2012, 09:19 PM   #4
Ryanbabz71
Ryanbabz71's Avatar
Doing mine (1st one on the car) tomorrow. Have done a bunch on my gm trucks
Tools
Ramps, dorman magnetic drain plug, 15mm gear wrench, ac Delco pf48 filter, 8 qts Mobil 1 oil (ss), oil catch pan, rags, oil filter wrench
Ryan
Ryan
Old 08-24-2012, 10:21 PM   #5
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
Don't forget the container of GoJo. Saved me many times from getting yelled at for getting the sink / door / etc dirty....
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 08-24-2012, 10:26 PM   #6
Ryanbabz71
Ryanbabz71's Avatar
Black nitrile gloves add to my list above
Ryan
Ryan
Old 08-24-2012, 10:31 PM   #7
Bradrulz
Can't forget the GoJo
Old 08-24-2012, 11:10 PM   #8
CamaroV6
Drives: Camaro V6 1LT Manual
I learned this the hard way......I was like it almost got my face lmao
CamaroV6 is offline   Reply With Quote
Old 08-24-2012, 11:16 PM   #9
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Haha in thee facee, sorry had too but i still have a large oil spill on my garage floor
On the bright side I didn't have to worry about my engine grenading bc of little/ no oil
Old 08-25-2012, 12:26 AM   #10
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
The car almost spit in my face the first time also lmao! The damn oil got all over my intercooler pipe which mad things worst lol. Who puts a drain plug like that anyways lol!
Can't_C_Me is offline   Reply With Quote
Old 08-25-2012, 02:15 PM   #11
Ryanbabz71
Ryanbabz71's Avatar
Hardest part was getting on the ramps they wanted to slide.
Ryan
Ryan
Old 08-25-2012, 02:34 PM   #12
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Is that an oil filter wrench? and a clean floor? what gives.
Old 08-25-2012, 03:46 PM   #13
Ryanbabz71
Ryanbabz71's Avatar
Yep that filter wrench is the best. Fits right on the bottom. Best $5 I ever spent on a oil change tool
Floor is clean only a few drips
Been doing oil changes on these engines 5.3, 6.2 since 2000 by far they are the easiest oil changes out there (location of filter and plug help)
Ryan
Ryan
Old 08-25-2012, 03:55 PM   #14
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
V6 is a little different for oil filter. 24mm I believe.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
amsoil, jack, oil, tire ramp
