![]() ![]() Drives: 2011 Camaro 1LT IOM Join Date: Jun 2012
I am thinking of starting to do my own oil changes as it is a fraction of the cost and you don't have to worry about someone not respecting your car.
Wondering what supplies/tools everyone is using for a 1LT V6? Tire ramps? Just a floor jack? Oil catch? What oil filter brand? What oil brand? I am thinking of using Amsoil XL, but still do the changes every 4,000 to 5,000 miles. Thanks for any advice. |
#2 | |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
Mobil 1 10w30 Wix oil filter
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
One of my lifts at work and Mobil 1 sorry I had too
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I use ramps. Got mine at Wally World. It is real easy to just drive up. Block the rear wheels.
I have been using Castrio Edge with a K&N filter. Next oil change I will be going to Royal Purple with a K&N filter. Just pick up a drain pan from any auto parts. If you use a K&N filter they have a 1" nut on the bottom. I think you will also need a 15mm on the drain plug. I have a Gold drain plug and it uses a 13mm. Good luck. I have been doing my own oil changes for 30 years. I heard Amsoil is great oil. When you do it yourself you know it was done right. ![]() Bill ![]()
![]() Drives: Inferno Orange 2SS Join Date: May 2012
just a note. Make sure the oil being used meets the Dexos 1 standard for the MY2011 and above. Castrol Edge meets it, as does the regular RP, have not found any hard data showing that the RP HPS meets this requirement. Should be a green Dexos symbol on the bottle indicating such. The Dexos 1 standard for the MY2011 and above was put into effect for improved performance and due to the timing chain issues in the V6 engines due to the longevity of the oil monitor system in the MY2010's that were going way beyond normal oil change intervals. This time span has since been resolved with an update in the 10's, but better safe than sorry for warranty reasons if something should happen. Just an FYI for those that don't know this already.
#6 |
Camaro 5 Muscle
Amsoil 5w-30 XL
Change it 3000 miles Mobil1 extended performance filter Hydraulic jack (small piece of 2x4 wood to use on jack pad so not to.damage undercarriage) Filter pliers to remove old filter 8 quart capacity Any questions pm me
Mods: Air Raid C.A.I., Custom Ported/Polished Throttle Body, Kooks 1 7/8 Headers, Dyno Tuned , LPE 3.91 Gears, BMR Differential Bushings, R/X Oil Catch Can, X-Pipe, Borla Exhaust, MGW Shifter, Hawk-HPS, SS brake lines, BMR front & rear sway bars, BMR rear sway bar end links, Pedders front radius rod bushings, Spohn front sway bar end links, BMR rack/pinion bushing, BMR Coils 1" drop, BMR Trailing Arm, BMR Toe Rods, Pedders Sub-Frame bushings, BMR Sub-frame Connectors, BMR Driveshaft Tunnel Braces, GM Strut tower brace, custom painted bowties
#7 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Since you have the V6, don't waste your money on a boutique true synthetic oil (group IV or group V) on the V6 because of the much shorter OCI's. You will waste your money by not fully utilizing the oils true capabilities. Off the shelf group III synthetics at WalMart I.E. Mobil 1, Castrol Edge, or even Pennzwater Ultra will be all you ever need to run as they are much better oils than the Semi-Synthetic Dexos blend that the dealers sell.
#8 |
Dead Man Riding
Drives: 2012 1LT Join Date: Jul 2012
Soon: Race Ramps, Wix filter, Pennzoil Platinum 5w-30
2012 1LT Silver Ice Metallic
RX Catch can/Breather GM Shock Tower Brace Front Bowtie delete Former Camaros: 1982 Z28 4 speed manual 1985 Z28 TPI automatic 1995 Z28 6 speed manual |
#9 |
![]() Drives: 2010 Camaro SS Join Date: Apr 2012
8 quarts 10w-30 Mobil 1 Extended Performance, Mobil extended performance Oil Filter, 2 rhinno ramps from autozone i agree driving up is easier than jacking up the car!
#10 |
2016 Camaro 1LT 2.0T
Drives: Nemesis Join Date: Feb 2011
I used my old rhino ramps briefly to install my skip shift eliminator, but I didn't think the car was level enough to do oil changes. Have you had any issues so far, or concerns not getting the pan completely empty?
| Tags |
| amsoil, mobil, synthetic |
