Old 08-25-2012, 04:55 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
SS master brake cylinder
Hey guys,
I have a v6 and am looking at upgrading the brakes the to SS brembo brakes. But I heard that if I do this I should also switch out the master cylinder so it is not as touchy. How much does the SS master cylinder cost? Where can I find one? Thanks.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 08-26-2012, 12:14 AM   #2
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Alot of people that have swapped to brembos are saying they didn't swap the master cylinder. And have no issues I guess that is my plan when I swap unless I hear otherwise
ICTsccaCamaro is offline   Reply With Quote
Old 08-26-2012, 12:18 AM   #3
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I'd try it without swapping first. Then if you aren't happy you can swap it later.
Old 08-26-2012, 04:30 PM   #4
JohnZ
JohnZ's Avatar
sounds good to me.
