08-27-2012, 08:37 AM | #1 |
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
Battery Voltage (Pictures)
So I am just curious how far down can your battery voltage go and still be able to turn your car on?
I am talking about this
08-27-2012, 08:48 AM | #2 | |
Drives: '17 GT350 Join Date: Mar 2012
Voltage does not really matter, it is the AMPS that deliver the power to start the car. A starter will crank at least as low as 7.5 volts. Voltage with no load tells you very little... |
08-27-2012, 08:52 AM | #3 |
Her Name is Mila
Ohhh ok. Is there anyway for me to know how many AMPS my car has easily? Lol
08-27-2012, 08:57 AM | #4 |
probably 11.9v w/o a load(engine not running)
08-27-2012, 09:08 AM | #5 | |
To do a starter current draw test.... You'll need a " clamp-on" ammeter and voltage meter. 1. Connect the tester leads to the correct positive and negative terminals and then connect the clamp-on amps pickup around one of the battery cables. 2. Set the voltage meter to Int 18V and adjust ammeter to read zero. 3. Disable the fuel or ignition so the engine will not start during test. 4. Crank the engine as you observe the testers ammeter and voltmeter. 5. Never crank engine for more than 15 seconds and allow the starter to cool for 2 minutes between cranks. |
08-27-2012, 09:27 AM | #6 |
Her Name is Mila
No I'm not having problems I was just curious.... Thanks for all of your input though!
08-27-2012, 09:44 AM | #7 |
Drives: Mostly Stock Join Date: Jul 2012
By the way, the Delco batteries that GM puts in their vehicles normally last pretty good in your area. I've seen fleet GM vehicles go 5 years on the original battery and personal vehicles normally go to 8 years of service.
08-27-2012, 09:53 AM | #8 |
Battery should put out 14.5 volts with no load. A battery only putting out 12 volts has a dead cell.
With car running, voltage tells you how well charging system is working.
08-27-2012, 09:57 AM | #9 |
Her Name is Mila
I don't know this is what my car say its running. Let you know my car is also off in this picture
08-27-2012, 10:00 AM | #10 |
it's hers...
Drives: 2011 Camaro 2SS/RS Convertible Join Date: Jun 2012
Must be nice, down here the concrete jungle will kill a battery
08-27-2012, 10:02 AM | #11 |
Her Name is Mila
My car idling (picture taken one minute after I turned car on and that was after I was using the battery in my car for 30 - 45 minutes without it running)
08-27-2012, 10:03 AM | #12 |
Actually the Delco batteries seem to last the longest for whatever reason. I'll only install Delco units in GM vehicles once the original one dies because most of the other stuff lasts 3-5 regardless of what they say.
08-27-2012, 11:37 AM | #13 |
5 year batteries last 3-4 years in Florida.
2013 Hot Wheels 2SS
08-27-2012, 11:53 AM | #14 |
Drives: 2012 LS M6, Black Join Date: May 2009
Three years out of a battery in Phoenix is pretty good.
I'd take that 12.1 volt battery in to have it load tested, probably. Colin's car is brand new. John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
