Old 08-27-2012, 10:11 AM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
18inch Wheels/ Brembo Brakes
Hey guys,
I just purchased a set of the stock SS Brembo Brakes and I wanted to know if there are any 18inch wheels that can fit over them? I want to put on the smallest possible wheel size to reduce rotating mass. Whiteline had a great looking wheels, 18inches, but the brembos wouldn't fit behind them.
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 08-27-2012, 10:33 AM   #2
Denis
Denis's Avatar
Drives: 2010 SS
i believe with the right offset 18's will clear but you need to remove the roller skates off the brake pads. im sure someone will chime in with actual facts though lol
just found this...
http://www.camaro5.com/forums/showthread.php?t=246120
Old 08-27-2012, 11:10 AM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
just found this...
He's got a V6 Camaro (non Brembos) so he should be good if he gets the correct offsets.
Old 08-27-2012, 11:58 AM   #4
JohnZ
JohnZ's Avatar
But I just purchased a set of the V8 Brembo Brakes, so they do NEED to clear the larger size.
Old 08-27-2012, 12:10 PM   #5
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Yes, there are some 18" wheels that will fit over the SS brakes. Try...Forgestar F14 or CF5. Or TSW Nurburgring or Interlagos. Talk with one of the reputable C5 vendors, I'm sure they can hook you up with the proper sizes/offsets.
blazzin1 is offline   Reply With Quote
Old 08-27-2012, 12:33 PM   #6
SGOS252382
SGOS252382's Avatar
Sorry, I saw that right after I posted. Get aftermarket pads and you should be good (as long as you get the correct offsets).
Old 08-27-2012, 12:39 PM   #7
JohnZ
JohnZ's Avatar
What vendors have you guys used/reccomend?
Old 08-27-2012, 01:01 PM   #8
blazzin1
blazzin1's Avatar
Use "Nineball" for all Forgestar purchases....without a doubt.
Old 08-27-2012, 02:26 PM   #9
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
I'd be glad to help. 18x9 and 18x10 Forgestar wheels clear the SS Brembos, but you'll need aftermarket brake pads without the rollerskate weights.
Tony
Fquick.com/NineBall
Old 08-27-2012, 04:07 PM   #10
JohnZ
JohnZ's Avatar
Tony
Thanks Tony! I am definitely going to get new pads (Hawk HPS). Will 18x9's fit all the way around?
I want to run the same tire size on all four corners. This is a daily driver that I take to autocross.
Old 08-28-2012, 10:02 AM   #11
Nine Ball
Nine Ball's Avatar
18x9 will fit all around. For auto-x, I'd probably go with 19x9.5 or 19x10 all around, and run a shorter tire like a 275/35-19 Nitto NT05. Check out this thread for two affordable auto-x combos. The 19" with shorter sidewalls is likely more responsive than some sloppy 18" wheel with a thick sidewall setup.
http://www.camaro5.com/forums/showthread.php?t=142387
Fquick.com/NineBall
Old 08-28-2012, 05:20 PM   #12
JohnZ
JohnZ's Avatar
I have a tune for my car, so I can have the diameter of the wheels for my speedometer changed. So I was thinking of going smaller wheels (18inch) as well as lower profile tires.
