Old 05-28-2009, 03:02 PM   #1
chevyryda
Drives: 1995 Covertible Camaro
Question rough idle and backfires, why? please help
my 1995 camaro with a 3.4L V6 starts up fine and runs good as long as i drive it. if i turn it off and turn it on it idles rough and backfires. i replaced the plugs and wires and cleaned the idle control motor and did not help. anybody have any ideas what could cause this?
chevyryda is offline   Reply With Quote
Old 05-28-2009, 04:00 PM   #2
Vash
Drives: 00 Blazer
Hum have you pulled codes? Check for vac leaks and maybe any play on your distributor.
The gears can wear out. I don't know much about that particular engine probably want to repost in one of the major 4th gen forums.
Old 05-28-2009, 05:03 PM   #3
chevyryda
i haven't pulled the codes yet. i was looking to see if anybody has had this problem or any advice before i took it in.
Old 05-28-2009, 05:41 PM   #4
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
Not sure what it would be off the top of my head but I'd definitely take it to an AutoZone or another auto parts place to pull the codes. That will help narrow down the possibilities. I take it your Service Engine Soon light is on?
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline   Reply With Quote
Old 05-29-2009, 12:26 AM   #5
chevyryda
check engine comes on after driving for awhile but goes away as i turn the car off.
Old 05-30-2009, 11:39 PM   #6
Boomer Sooner
Banned
Drives: my girlfriend nuts
I was having similiar problems on my 99 z28. Turns out it was my cam sensor.
Boomer Sooner is offline   Reply With Quote
Old 06-07-2009, 09:00 PM   #7
Bismarck318
Drives: '94 Base... Grounded due to E-Check
Similar problem about 4 years back, it simply went away unexplained, now I'm having hard starting problems.... no codes.
Would that be the crankshaft sensor?? Similar problem on a Bonneville years back, car would at times not start.... I'm experiencing the same problem now with the Camaro, alternatively it could also be the fuel filter.
Bismarck318 is offline   Reply With Quote
